Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 06-23-2010, 04:25 PM
Pacific Bearing is on a distinguished road
Lightbulb Simplicity® Bearings Installed into Acushot’s™ Needle-free Injection Gun
Healthy animals are necessary for efficient stockyard production. Disease and other bacterial conditions thrive in close quarters; making regular vaccination for all livestock a natural pre-requisite. However, implementing and documenting consistent injections for all animals is tedious, expensive and, in some cases, hazardous. To solve these problems, Acushot, an innovative veterinary design company, designed an automated, needle-free injection gun for mass livestock vaccination. The design required a linear bearing system to absorb recoil. Acushot™ turned to Colpitt Designs, who recommended PBC Linear’s Simplicity® plane bearings for the task.
Typically, hand-held needle injections were used for vaccinating the animals in the stockyards and barnyards; however, with thousands of animals coming through production at once, succesfully and safely supervising the injections became an increasing concern. Acushot’s™ new system eliminated needles, removing the possibility for an unsafe employee needle-slip. The unit also enhances sanitary conditions, the battery powered injection unit can be used hundreds of times without risk of cross contamination to the animals.
For a rapid prototype and possible added refinements to their design, Acushot™ turned to Colpitt Designs—a third party engineering firm. Colpitts worked to reduce components and assemble the triggering/injection system by using a varying degree of strength gas cylinder to provide up to 600 pounds of force. The system also automatically saves each dose with a time stamp for accurate vaccination records. The cylinders are designed to inject the vaccines to the same recommended depth as a typical needle that would have been used on a range of animals. The injector can be set to inject from 0.2cc and deposit it just in the skin of the animal and up to 2.5cc can be injected to the recommended depth into the muscle of the animal.
Colpitts immediately set to work. Using a simplified approach, they were able to reduce moving components and make the design more cost-effective; while still adhering to Acushot’s™ criteria. The final product was a lightweight, compact and battery powered needle-free injection unit that packed up to 28,000 psi delivery pressures while concurrently documenting each injection.
One obstacle to overcome was finding a linear bearing assembly to support the force of the injection delivery. Throughout a cycle, 650 lbs of force act on the bearings; which would be under constant use in extreme temperatures and outdoor working conditions. To solve this, Colpitts Designs used Simplicity® plane bearings to withstand the system parameters and environment of the application.
Simplicity® bearings glide using a proprietary Teflon liner. This provides even disbursement of forces throughout the bearing and smooth, reliable travel. Bronze and linear ball bushings spall the shafting under the high forces and short stroke which accumulate and
contaminate the system; resulting in catastrophic failure. Simplicity® bearings self-lubricate to ensure smooth and quiet operation for constant or intermittent use. They also thrive in temperature extremes (from -400°F-400°F)! These design factors allowed Simplicity® to drive consistent and satisfactory performance of Acushot’s™ injection gun.
No needle trauma recovery was necessary for the animals; in fact the livestock does not even take notice when given their injection with Acushot’s™ new injector. The new injection unit also reduced the diameter of the injection mark to about 1/8th the size. Easy to use with no extra vaccine containers the Acushot™ system improved productivity, safety and the overall health in stockyards and barnyards world wide. For more information on PBC Linear or Simplicity® technology, please email us at marketing@pbclinear.com. You can also contact us by phone at 1.800.729.9085, or visit us on the web at our RST dedicated webpage: RST.pbclinear.com.
For more info on Acushot™ or Colpitts Designs, please visit them at their respective websites:
http://www.colpittsdesign.com/
http://www.acushot.ca/
Tags
linear bearings, pbc linear, plane bearing, self-lubricating, simplicity
Simplicity® Linear Bearings Help Keep the Automotive Industry Running Pacific Bearing Product Announcements & Manufacturer News 0 03-30-2009 08:43 AM
Whats the point of these needle thrusts bearings? georgeburns DIY-CNC Router Table Machines 6 05-05-2008 05:18 PM
Small Needle bearings..... IN-WondeR Mechanical Calculations/Engineering Design 0 01-24-2008 04:56 PM
Needle Bearings and Dowel Pins Alex Westling Mechanical Calculations/Engineering Design 2 01-18-2008 11:34 PM
Needle thrust bearings cncuser1 Mechanical Calculations/Engineering Design 6 09-18-2006 06:13 AM
