Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 06-01-2010, 02:10 PM
Jetedge is on a distinguished road
Arrow Jet Edge Water Jet Pump Features Redundant Intensifiers
Jet Edge’s iP60-50R water jet pump has two intensifier systems. If one of the intensifier systems should fail or require service, the second intensifier system can continue operations until the intensifier pump can be shut down for service.
The iP60-50R produces 1.1 gallon (5 liters) per minute of ultra-high pressure water for precision water jet cutting, water blasting, cleaning and surface preparation applications. It supports orifices up to .015” (.38 mm).
Like all Jet Edge waterjet pumps, the iP60-50R features Jet Edge’s reliable tie-rod design. This design has no threaded cylinder, no threaded end caps, and no threaded hydraulic cylinder, making it less prone to cracking than threaded designs. Matched-metal components prevent galling of hydraulic system components. Jet Edge water jet pumps feature hydraulic accumulators, which reduce wear on the hydraulic pump. Hydraulic fluid also is cooled and filtered. Jet Edge waterjet pumps feature a rugged hydraulic center section which incorporates high-duty cycle-rated piston seal and wear rings. Jet Edge’s hydraulic systems have a 4,000-hour warranty. Jet Edge water jet pumps also feature attenuators which smooth pressure fluctuations and deliver a constant and steady stream of ultra-high pressure water to the cutting tool, ensuring optimal cut quality.
Information
For more information about Jet Edge waterjet pumps, visit www.jetedge.com or call 1-800-JET-EDGE (538-3343).
INFORMATION REQUEST FORM
About Jet Edge
Established in 1984, Jet Edge is a global designer and manufacturer of waterjet systems for precision cutting, surface preparation and coating removal. Jet Edge systems are used around the world in a broad range of industries, from the world's leading airlines to automotive, aerospace, industrial manufacturers, machine and job shops. Jet Edge waterjet systems are proudly made in the U.S.A. For more information about Jet Edge, visit www.jetedge.com, e-mail sales@jetedge.com or call 1-800-JET-EDGE (538-3343).
Tags
water jet, water jet cutting, water jets, waterjet, waterjets
Just IN- 100HP Waterjet Intensifier Pump Features Reliable Tie-Rod Design Jetedge Product Announcements & Manufacturer News 0 08-31-2009 08:38 AM
Just IN- Waterjets Manufacturer Jet Edge Introduces 36KSI Diesel-Powered Water Jet Pump Jetedge Product Announcements & Manufacturer News 0 07-13-2009 09:48 AM
Just IN- Jet Edge Introduces 50HP 90,000 PSI Waterjet Pump Jetedge Product Announcements & Manufacturer News 0 03-19-2009 04:02 PM
New Video Features Michael Waltrip Racing's New Jet Edge Waterjet Cutting Machine Jetedge Product Announcements & Manufacturer News 1 07-10-2008 05:22 PM
Water Pump control CNCadmin Mach Software (ArtSoft software) 6 07-08-2005 06:52 AM
