Results 1 to 5 of 5
Thread: Do you recognize this cutter
    Sep 2007
    Anybody recognize what brand or model this cutter is:
    http://gasketsondemand.com/order.php3
    Thanks, Ron
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    Excellent marketing From picture on site impossible understood anything. Ask them did this plotter have tangential blade? If NO - buy any chinese for $500 and work without problems
    I think gasket material is not big problem for any plotter.
    Feb 2010
    india
    grass cutter
    Sep 2007
    What's a grass cutter? This cutter uses a blade like the one in a Roland cutter, it rotates 360 degrees. Any recommendations on a cutter? Thanks, Ron
    Jul 2008
    Lithuania
    ranchak - I also do not understood what rameshthota means, but don't worry - buy any curring plotter nearest to you. If you have money - buy GCC, Roland, Western Graphtec. Limited money - look for noname Chinese plotter.
    You can do what you need with any plotter. The problem will be only blade durability. To keep good quality you must change blades very often.
  1. Does anyone recognize this Fanuc?
    By Dancy in forum Fanuc
    Last Post: 02-25-2010, 12:42 AM
  2. Recognize this profile
    By plcamp in forum Mechanical Calculations/Engineering Design
    Last Post: 03-19-2009, 08:07 AM
  3. Anyone recognize this connector?
    By cnczoner in forum General Metal Working Machines
    Last Post: 09-09-2008, 10:34 PM
  4. SHW UF-2 & ISA 40 anybody recognize?
    By innova in forum General Metal Working Machines
    Last Post: 04-12-2007, 05:13 PM
  5. Can you recognize yourself?
    By ESjaavik in forum CNCzone Club House
    Last Post: 05-28-2004, 10:32 PM
