Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 03-15-2005, 09:45 PM
VNSPEC22 is on a distinguished road
HP 7470A Plotter
Can you use this plotter with CAM software to emulate a CNC machine? I am interested in using it to try to plot some sample G code I have written. I have KCAM4, Corel Draw 9, AutoCAD2000 and Photoshop elements, what is the best to try and use? Also how can I hook it up to my modern PC's with only USB,serial and parallel ports running Win98SE/XP?
Old 03-15-2005, 10:42 PM
fyffe555 is on a distinguished road
The HP 7470 is an HPGL plotter. To use it as a native plotter from any OS you need the appropriate driver. There's a driver for Win9x but not for Win 2k, NT or XP, so you can't use any HPGL device in the later OS's native.
Autocad can drive the plotter directly from any OS by setting up a custom plotter under autocad and specifying the port and connection. The autocad 2000 help is pretty good at explaining it.
To plot G-code on the plotter you have to convert it to HPGL. You could import your Gcode into a DXF in autocad directly, a contributer here has posted an autocad program to do this, and then plot the dxf to plotter with autocad managing the HPGL side. I have done this with my Mutoh F920 which is a HPGL only plotter of the same vintage.
Note that the conversion process might change the output somewhat, or miss some codes entirely.
If you smply want to see the actual product of your Gcode I'd recommend CNC Simulator. Its a free software that does a realtime toolpath emulation on the PC. Saves Paper !
Andrew
Do a websearch for a Gcode interpreter to convert G-code to HPGL. Several machines and manufacturers have used HPGL to operate machines and input Gcode and you could then print the file directly.
Old 08-16-2005, 10:38 AM
Nathan Vaksman is on a distinguished road
Nate
Where should I look for the conversion og G to HPGL conributor file.
HP 7475A Plotter Help VNSPEC22 Printing, Scanners, Vinyl cutting and Plotters 26 08-22-2010 10:10 AM
XP driver for HP plotter Fixxit Printing, Scanners, Vinyl cutting and Plotters 11 09-05-2007 02:56 AM
Using KCam and Hp 7470a Plotter VNSPEC22 Kellyware CAM 0 03-15-2005 09:35 PM
1012 plotter 2muchstuff Printing, Scanners, Vinyl cutting and Plotters 3 02-25-2005 11:39 PM
Making use of Plotter Steppers Al_The_Man General Electronics Discussion 1 09-11-2004 03:15 PM
