Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 12-21-2004, 03:19 PM
BK2_SHOOTER is on a distinguished road
Software to make Xsections of an .STL file
Hi guys,
Im looking to use a plotter/cutter to make 3D objects, I can make .STL files of the 3D part, but need some software that will slice it up and export it at a load of .DXF files of the sections. I know this is possible, but I dont have the money to spend on expensive software to do this. Does any one know of any software that will do this on a budget.
I look forward to hearing from you guys. or if you have ideas of other ways of doing this then let me know!
Cheers
Martin.
Emco Compact 5 PC...have ???? Double G Mini Lathe 42 08-22-2010 07:26 PM
Software to cut .STL in to slices BK2_SHOOTER General CAM Discussion 4 12-23-2004 02:21 PM
***One stop CNC software guide*** ynneb DIY-CNC Router Table Machines 4 05-27-2004 05:31 PM
how do i make a .cnc file? ljoe1969 TurboCNC 3 01-14-2004 09:56 PM
