Results 1 to 2 of 2
Thread: Roland CAMM-1 Stuck in a test Plot Loop
    Dec 2008
    Ireland
    Exclamation Roland CAMM-1 Stuck in a test Plot Loop
    Hi Folks,
    This is a post of pure desperation, I have been online for hours with this and no joy
    We have a Roland Camm 1 PNC 1210 Plotter that was previously working.
    Now for some reason no matter what is sent to it it cuts this string of Characters, regardless of what is sent to it.
    It shows the error: "Er 2: Wrong Number of Parameters"
    We are completely stumped as to why it is not working.
    Using latest driver from Roland
    Windows 2000
    Sign Lab 5
    We are using Sign Lab to design, which seems to be working fine.
    Nov 2006
    Your plotter needs to be set to MODE 2
    It is probably set to mode 1
    You change this on the plotter itself.
    Mode 2 is HPGL.
    Mode 1 is Rolands own language.
    Signlabs drivers are HPGL so the cutter needs to be set to Mode 2
  1. Open Loop to Closed Loop Stepper Conversion
    By beamhome in forum Stepper Motors and Drives
    Last Post: 08-14-2012, 03:58 AM
  2. Replies: 8
    Last Post: 06-06-2009, 10:40 AM
  3. Need Help!- Roland CX-300 Camm-1 Pro
    By SignFX in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-19-2008, 10:22 PM
  4. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors and Drives
    Last Post: 11-09-2007, 01:30 PM
  5. Lathe conversion - open loop vs closed loop
    By bhowden in forum General Metal Working Machines
    Last Post: 03-21-2006, 04:56 PM
