Results 1 to 7 of 7
Thread: Rabbit hx 800 cutter/plotter
    Sep 2008
    south africa
    I bought a new rabbit hx 800.I ve got Windows XP.I need to install it as a printer/cutter to use it on coreldraw 12.It seem there is no compatable drivers for Windows on the cd. Pse can anybody help?
    Oct 2008
    India
    hi,
    Pls letme know about yur plotters , which drivers you are using in FlexiSign presently?
    Jul 2005
    Take a look at SignGO software.
    Can drive many different sign cutters.
    Sep 2008
    south africa
    Thank you for reply.It is a Rabbit HX800 Cutter/Plotter,it came with artcut software.Driver provided-hxlaser,Version 2.7.2007.6,Not digitally signed.
    Thank you
    Riaan
    Jul 2005
    HP-GL / DMPL compatible (per the specs on the HX800)
    I re-read your first post... you want to use with Coreldraw... that can be done but you will have to use a program called CoCut... it was written to allow people with coreldraw to cut on their cutter/plotter. Go to CoCut.com
    Mar 2011
    portugal
    hI
    For install Rabbit to work with COrel u must hava a drive that is called CUTTING MACHINE
    and is installed like a printer at COM1 , also need to install the drive to comunicate with the machine that is include on the drivers CD.
    Plus u need to be shure that u v WINDOWS SP2 on y PC without this could not run properly
    Aug 2011
    Bulgari
    If you have a solution can you send me the rabbit hx 800 drivers to this e-mail joro_merdjanov@abv.bg. Thanks! I tried with artcut 6.0 but it didn`t have the hx 800 drivers, so it didn`t work.
    1. Need help with RABBIT vinyl plotter
      By hodge98ws6 in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 05-11-2010, 09:30 PM
    2. Rabbit 3040 laser cutter with Mach3 ??????
      By Mrebeiro70 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 05-17-2009, 10:38 PM
    3. Vinyl Plotter Cutter
      By it_inspector in forum Want To Buy...Need help!
      Last Post: 06-10-2008, 04:42 PM
    4. How to make your own plotter/cutter
      By CNCadmin in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 09-12-2006, 01:58 PM
    5. Vinyl cutter/plotter
      By jleiwig in forum DIY CNC Router Table Machines
      Last Post: 11-29-2003, 09:27 PM
