Results 1 to 6 of 6
Thread: Bitmap to .EPS
    Mar 2008
    Bitmap to .EPS
    Im a newbie to the world of cutting! go Figure Right. Im trying to convert a bitmap to .eps or some that signblazer will cut. Ive tried to convert save as and other mind blowing things and Im about exhausted. I know that someone can shed some light on this. After conversion and adobe illistrator, corel draw the file extension shows .eps however when I go to cut it gives me a error saying its a bitmap....
    Help
    Thanks in Advance
    Mar 2008
    United states
    bitmaps
    I had the same problem using Lxi8 software. I went to vectormagic.com and vectorized my bitmap online. I am also very new to vinyl sign work. This was very easy and it only cost 3.00. You can play with it until you are satisfied before you download and pay. I downloaded it as an eps file and saved it. then I imported it into my sign software. It worked great.
    Of course, now I have another problem. When I used the logo again I did something that put a box around it and I can't figure out what I did or how to get it off. It will still cut the logo, but it also cuts the frame. Anybody got any idea how to lose the frame? I hate being stupid!
    Hope this will help.
    Mar 2008
    Smile
    csdecker,
    Thanks for the help. I tried the site and it was exactly what I was looking for. I used the 2 free tokens and I wish i could get the week back...
    Again Thanks
    Steve
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Bitmap to Vector Conversion
    Adobe Illustrator CS3 is very good for bitmap to vector conversions
    There is a student version available for a little less than $200.00
    http://tinyurl.com/375y5a
    Jeff Alessi
    jalessi@aol.com
    Registered swaneejuggalo's Avatar
    Apr 2008
    us
    Download inkscape and use the trace bitmap function get it how you want it then save in .eps format and open in signblazer
    Registered jimmycakes's Avatar
    May 2008
    Another trick if you have Photoshop and Illustrator. Copy your image and paste it into a new channel. Alt + Click (or CTRL + click, can't remember right now) on that channel and it will give you an option to load it as a selection. You can then click on the little circle on the bottom of you channel palette and convert it to paths. You then go to FILE>EXPORT> PATHS TO ILLUSRATOR. Sounds a bit crazy, but it has saved me a few times.
  1. 3d relief from bitmap
    By walter in forum DIY CNC Router Table Machines
    Last Post: 01-02-2013, 08:16 AM
  2. Bitmap trace
    By tdnp in forum Vectric
    Last Post: 02-20-2008, 05:11 PM
  3. How To Trace A Bitmap Or Image!!!!
    By jmedick in forum Rhino 3D
    Last Post: 11-02-2007, 08:25 PM
  4. Tracing a bitmap in Rhino
    By gregrnel in forum Rhino 3D
    Last Post: 09-24-2006, 02:50 PM
  5. How can I get a bitmap to display in the forum.
    By ynneb in forum Forum Questions or Problems
    Last Post: 06-18-2004, 10:10 AM
