Results 1 to 7 of 7
Thread: some kind of communication problem
    Mar 2008
    I am very new to vinyl cutting. I have been playing around trying to figure all of this out. I have done a few cuts and things seemed to go well. But now for some reasons my computer not communicating with the plotter. I called tech support and we tried several different things and they finally decided that it has something to do with my anitvirus. So I disabled it. Still no go!!! Any suggestions. Thank you
    Oct 2006
    UK
    I'm a bit rusty as I retired from cnc routing and vinyl cutting about 5 years ago, but the usual problem was the file being sent to the cutter. Most vinyl cutters use HPGL file to cut or plot with and if you have not converted your file to a .plt file the cutter will not recognise it. Some dedicated cutting programs will do this automatically but programs such as Coreldraw need additional work to run successfully. As a matter of interest what program are you using?
    May 2006
    first things first what cutter? what connection ? what software? as Most aren't mind readers & there are many different equations to this problem it helps to start in correct Book then we can find the page. You might have to have special cable. could be line weight in software. Not on here much so you might PM me
    Dec 2005
    UNITED STATES
    Having used my cutter exactly once, successfully, the following suggestions:Reboot.
    Plug in cables. If USB to parallel, use your cutter software to select the proper USB/Plotter driver/communication, kind of like selecting a printer. The hold downs for the vinyl need to be at the outside edges of the cut area, over "sandy" rollers, or the plotter cuts partial numbers. US Cutter maching. LOL
    Nov 2006
    JamsAirbrush
    Frequently disabling your firewall/anti-virus doesn't actually stop it from blocking communications. I have had this happen with wireless connections.
    If all else fails,you might try removing ( uninstalling ) the anti-virus program and see if your cutter works.
    HTH
    Sep 2007
    U.S.A.
    Please give a complete overview of what cutter/Plotter, software, OS etc... Gary Karm out... PS: I have been cutting vinyl for over 25 years on several different machines and OS= operating systems.
    Dec 2007
    What kind of plotter do you have and what driver did they tell you to use?
    also what software and are you inputing dxf?
    Papad50
    1. communication problem between mach3 and pc
      By ataxy in forum Mach Software (ArtSoft software)
      Last Post: 01-21-2008, 07:36 PM
    2. TNC 370 communication problem
      By Flatdog in forum Bridgeport and Hardinge Mills
      Last Post: 01-09-2008, 08:20 AM
    3. Communication Problem
      By LEGCNC in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 05-29-2006, 09:34 PM
    4. Infra red communication problem
      By jtree83 in forum Computers and Networking
      Last Post: 04-17-2005, 11:06 PM
    5. Communication Problem
      By Alex S.A in forum Computers and Networking
      Last Post: 01-28-2005, 10:38 AM
