Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 05-26-2004, 09:15 PM
Fixxit is on a distinguished road
Question XP driver for HP plotter
Does anyone know if there are any Microsoft XP drivers for HP plotters out there? I did a search and couldn't find any.
I have an 11x17 inch flatbed plotter that runs HP 7475 compatible code. The plotter still works.. (using a 1985 vintage Autocad release 9, on a DOS based '386 machine.)
I now use Intellicad 4 which does not contain any drivers for Microsoft XP to run the plotter. Can anyone point me to a source for this software.
Thanks!
Fixxit
Old 05-26-2004, 09:20 PM
BrianS is on a distinguished road
This is not to be a smart-ass comment, but did you try HP's site?
Brian
Old 05-26-2004, 10:13 PM
Al_The_Man's Avatar
Have you tried to add a printer under windows? and it will give you a list of HP Plotters, you will have to probabally put the Original XP CD in to extract the driver.
Al
Old 06-28-2004, 05:38 PM
fattuna is on a distinguished road
old HP plotter
I did this about 2 years ago. I have also in my attic a HP pen plotter 11X17 (or something similar). The last I remember is that thdriver was still avaible on HPs website but if you cant find it you'll have to call or email printer or plotter repair shops and they'll usually have a disk laying around or could direct you to a BBS site...(yeah the software is that old) also they might be hesitant to send you a copy but sometimes you get a guy thats in a pretty good mood.
by the way: I plan on taking the plotter a part and building a small CNC for a dremal...anyone any advice?
later
fat tuna designs
Old 06-28-2004, 06:01 PM
jimini is on a distinguished road
Hi Fattuna
A year or 2 ago I bought several plotters with that in mind.
I took them apart and found very small motors (but fast), not steppers and of course your Z axis would only have pen up and pen down.
I never did use any of the parts, so I wouldn't recommend that route....................................Jim
Old 06-29-2004, 10:16 AM
Stepper motors for free:
If you can find any old IBM 5 1/4 inch disk drives there is a pretty good stepper motor inside, that was used to position the head. It is a unipolar drive (a common lead connected to all the windings) you just sequentially connect the coils to ground through a driver circuit. The windings are for 12 volts and don't draw too much current. These stepper motors also do fine on 5 volts, but the torque is reduced, but not bad. You will have to really squeeze the shaft with your fingers to stall the motor even at 5 volts. I have used several in various projects. Free is the best price. Some of the older 20 meg hard disk drives also had a good stepping motor.
Hold on to the plotter, If I can find a driver I will share it. The plotter may not be enough to hold and run a Dremel tool, but it is a precision instrument and an application may present itself.
HP does not list the old plotters on their site. There is a plotter driver for HPGL2 (Hewlett Packard Graphics Language) in XP, but it does not work with the original HP plotters (I guess that that version was HPGL 1.0 ;-)
The problem is microsoft XP to the original HPGL.
Old 06-29-2004, 11:16 AM
tjstraz's Avatar
tjstraz is on a distinguished road
Hello Fixxit. I also own a HP 7475, but have not dusted it off in a while to use it under XP. However, I did find a link with the solution you are looking for: http://forums.windrivers.com/archive/index.php/t-59464
They specify the HP-GL/2 driver when you install it using the add printer wizard.
Let us know if this works.
Tim
Old 06-29-2004, 12:30 PM
Gnu's Avatar
Gnu Gnu is offline
Gnu is on a distinguished road
I have two samsung disks at 420mb Can they be of ny use?
Building machines since 2005
Old 06-30-2004, 12:40 AM
Samsung drive
The high capacity drives (> 40 MB) usually don't use stepping motors to position the heads. They use "voice coil" technology. A coil of wire is attached to the rear side of the disk head positioning arm. The field created by this coil acts against a pair of nearby magnets. The position of the head and coil is proportional to the current flowing through the coil.
The good stuff to salvage from these drives is a pair of really powerful magnets inside the drive case. You have to remove a bunch of really wierd security screws to get inside the drive enclosure. IT is worth the effort to get these really powerful magnets.
Thanks for the HP 7475 driver leads... I will check them out and report.
Old 07-05-2004, 06:03 AM
c-c-cncboy is on a distinguished road
Hey Fixxit: If the sources quoted for genine HP drivers don't work, then go to www.rolanddg.com (Roland Japan) and click on DOWNLOADS and choose from the GRX and GSX and DPX series of plotter drivers. HP7585 was an A0 size, so GRX-4nn or GSX-4nn would likely work for you. Roland's RD-GL language was compatible with HP-GL. Happy plotting. Terrence
  #11   Ban this user!
Old 09-05-2007, 02:53 AM
smitjs is on a distinguished road
You need the file HPGL_Roland.zip, which is free.
My Roland DG DXY 980 also understands HPGL/1 only, and works well with this driver
  #12   Ban this user!
Old 09-05-2007, 02:56 AM
Thanks!
Fixxit
You need the file HPGL_Roland.zip, which is free. It uses HPGL/1 only, and works well with my Roland DXY 980A, which is compatible with HP 7475A
PIC Open source Servo Driver Schematics development? Rossz Open Source Controller Boards 90 10-26-2011 04:37 PM
HP 7475A Plotter Help VNSPEC22 Printing, Scanners, Vinyl cutting and Plotters 26 08-22-2010 10:10 AM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 06:05 PM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 02:18 AM
Selecting stepper driver components... fyffe555 General Electronics Discussion 0 09-26-2003 10:50 AM
