Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 07-14-2007, 08:12 AM
Kool Parts's Avatar
Kool Parts is on a distinguished road
nextengine 3D scanners
Anybody have experience with these...cant be that easy and cheap...or can it??
https://www.nextengine.com/indexSecure.htm
Old 07-14-2007, 09:17 AM
SCROMAL is on a distinguished road
I also would like to know about the scanner.
Can anybody send a actual scan from that machine?
You can pm me at scromal at aol dot com.
Thanks Steve
Old 07-14-2007, 01:18 PM
Kool Parts's Avatar
Never mind...just found a long thread in a different part of the site. Tooooo many friggen sections in this web site
"New" 3D Scanner from NEXTENGINE
Old 07-15-2007, 04:25 PM
motor818 is on a distinguished road
Online Demos Available
Tool path generation from scan data is an obvious use of the NextEngine scanner but there is also a scan vs cad model comparison tool in ScanStudio PRO. There is also a package that will allow generation of parametric cad files by using scan data to draw to.
File formats available are Mesh, Surface and Solids. The respecitve software solutions for creating these formats are ScanStudion CORE (comes with scanner, standard) ScanStudio PRO upgrade, $995, and RapidWorks $2,495.
All three of these file types are generate from point cloud data and the scanner does a remarkable job of generating high quality scan data (50,000 points per second). -yes I do work for NextEngine and can tell you that we are conservative in the specifications pubished.
Will keep any posts objective...
Old 07-19-2007, 04:19 PM
Palafox is on a distinguished road
I am evaluating the scanner purchase. The ScanStudio PRO upgrade is the only feature I do not know if it will fit my needs.
Can you explain which features I will be missing if I do not buy it? Which advantages has over the Core version?
Thank you
"New" 3D Scanner from NEXTENGINE Kiwi Digitizing and Laser Digitizing 159 08-12-2011 08:58 AM
Scanners and Mach 3 monte55 Mach Software (ArtSoft software) 3 11-19-2006 10:30 AM
