Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 06-19-2007, 03:40 PM
coltons customs's Avatar
coltons customs is on a distinguished road
Exclamation hp 7580 b
i am in the process of converting an hp 7580 b into a vinyl cutter i have found that a mimaki bladeholder fits my machine perfectly however i can not apply enough downpressure to cut sandblast mask material to fix this i fill a ballpoint pen tube with lead and affixed it to the head with 3m douuble sided tape aprox 3 ounces of lead the next prob i ran into was nife movement or wander to fix this i attached a rubber band around the clamp to hold the blade better seems to work as long as the pen speed is set slower than 6 otherwise it wanders upon sharp corners the next probi encountered was that the pen lift spring was not strong enough to lift it entirely off the material i installed a heavier spring ( carefull as to much spring and the pen down function will not work now my current problem i dont have a manual for my machine and am trying to adjust the platten pressure my material was to thick to load so i backed off the pinchwheel adjusters to get the material in after pressing chart hold it does its thing and then from what i know you can press axis align and it will align its limits and it did this with paper origionally know it just spits the material out the other side. any help would be awesome or if anyone has a manual the can spare or possible scan and email would be great as that the only one on ebay the guy wants more than i payed for the plotter to purchase it
Old 06-23-2007, 06:14 AM
PeteA is on a distinguished road
G'day,
Try here http://www.hpmuseum.net/exhibit.php?hwdoc=76
and here https://82.230.23.148/hp/dj-cd/new-l...ce_manuals.htm
I am currently repairing my own 7585B for eventually cutting vinyl, so I am interested to see how you go.
Old 06-24-2007, 10:34 AM
Thumbs up
finally hey thanks for your help i was beginning to get aggravated with trying to figure it out without any manuals so thanks again and let me know if i can help with your project i currently have got mine set up so it will plot and cut vinyl and sandblast mask material i just had to make sure i had media loaded that was about twice the size of my project but now i have figured out how to set its limits and it seems to work good . but thanks again and if you got questions don't hesitate to ask
colton
