Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 04-05-2004, 02:39 AM
vacpress is on a distinguished road
CNC Gantry Painter Build Pics - Night 1
Tonight i printed templates for the sides, and cut one with a scroll saw. took forever.. gonna goto school tomorrow to cut the other 3 with a bandsaw, and use their sanders to clean up the cuts and make all 4 side panels identical. to do this, i am going to put bolts through the axel holes, and bolt them all together before sanding down to size.. gotta read about polishing the edges of acrylic.... heres some photos.
this photo shows an old part for another machine with the wheels laid up next to it.
Name:	faux gantry setup.jpg‎
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
Old 04-05-2004, 02:42 AM
Another faux setup
I thought you guys might wanna see more of this gantry assembly. i decided not to use it because i want something a bit different for this. i will stick to my plans. i put lots of work into it though. its made of john Ks window channel, but used totaly different. i riveted a bunch of it together to for this structure, then painted it.. took an evening... then i mounted a bunch of poorly machined aluminum bearing blocks.. TAKE time when seting up your drills and cuts! its worth it.
Name:	faux gantry setup2.jpg‎
Old 04-05-2004, 02:43 AM
The actual parts
Heres 1 part cut, 1 part patterned.. The cut is SOO rough with the scroll saw... gotta have patience and wait till i can use a bandsaw for this... gonna sand all the parts true...
Old 04-05-2004, 02:47 AM
One side layedout
heres 1 side laid on a bench
Old 04-05-2004, 06:04 AM
teilhardo is on a distinguished road
Wow Vac, I envy your speed. Looking good at this point.
By day 5 you'll have your own billboard on Madison avenue
-Please check out my webiste-
http://www.teilhardo.com
Old 04-05-2004, 10:14 AM
Konstantin's Avatar
Konstantin is on a distinguished road
And vacpress will rest on the seventh day.
He he. Nice work there.
Realy impressive.
Konstantin
Old 04-05-2004, 10:25 AM
kcoaks is on a distinguished road
Did you ever find anything out about polishing the cut sides of acrylic?
Old 04-05-2004, 10:28 AM
i didnt get nearly as much as i wanted done. i had to stop cuz it was 2am and my roomies were like "why are you sawing?"
kcoaks- no. im gonna ask today at the school shop, maybe the shop leader guy knows.. if not, im sure its just a buffer wheel... i hate my buffer wheel though - it makes a very scary noise.
Old 04-05-2004, 10:43 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Vacpress - when I was about your age (seems a while) in the sign shop we used a hooked knife to round over the edge of plex - but that was scary too! Also a wheel (sanding disk) hand held on a drill or belt sander - but then again on a sign 40 feet++ in the air you never notice the small imperfections.
I have seen flame-ploished and "melted edges" on some plastics - but control of the heat is important so you don't "flame" the project.
Maybe a beat up iron from goodwill/sallys?
Progress is amazing! Keep it up!
cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
Re: Another faux setup
...just wanna see MORE!
  #11   Ban this user!
Old 04-05-2004, 03:34 PM
publitime is on a distinguished road
vac
Whene you need parts in plexi ore something i will mill theme for you.
I have made a big cnc milling machine.
At this moment i didn't found a way for cnc color controlling.
Did you found something yet?
  #12   Ban this user!
Old 04-05-2004, 04:25 PM
publi - i think i did find something out. basically a mix of image processing software to get the pics ready and in a basic "Raw" format. then a program that takes that data and reads it.. it turns out we dont have to "mix" paint.. not really. gotta get the dots small enough that the colors are made up of small dots - like a page in a magazine
as for getting parts machined - that would be great if i didnt have access to a very good AXYZZ machine at school. i cut some parts with a bandsaw and think they suck. so i am gonna get a new piece of plexi and use the CNC here to do it on wed.
if you want the 3D files to build along - that would be very cool.
Open Team Cheap DIY CNC Moving Gantry Router pminmo DIY-CNC Router Table Machines 94 08-19-2007 02:59 PM
CNC Gantry Painter Build Pics - Night 2 vacpress Printing, Scanners, Vinyl cutting and Plotters 7 11-02-2006 07:52 AM
Looking For Someone close to London So We Can Build A Cnc Each chris69randy DIY-CNC Router Table Machines 29 07-15-2005 03:26 AM
Homebrew CNC Gantry Painter vacpress Printing, Scanners, Vinyl cutting and Plotters 48 04-07-2004 09:02 PM
