Page 1 of 5 1234 ... LastLast
Results 1 to 12 of 49
Thread: Homebrew CNC Gantry Painter
    Mar 2004
    Heres the first 4 hours of a potential design:
    The friction belt is driven directly by the stepper which has 10x microstepping driver
    the airbrush is $10.00 from harborfreight!
    Design & Development
    My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
    Mar 2004
    More Digital Images
    Mar 2004
    any solidworks users want the files? i would love if someone would do some mods.
    this is the last digital image. i have all these parts allready, thats what inspired the particular design choices. i will take apicture of them and make a parts list.
    Jan 2004
    incredible drawings. solidworks?
    Mar 2004
    yep. solidworks. started at 2:30am, this far along at 6:30am
    Jan 2004
    get some rest. you look tired.
    Attached Thumbnails Attached Thumbnails Homebrew CNC Gantry Painter-p242.jpg
    Gold Member Bloy2004's Avatar
    Oct 2003
    Sturgeon Bay, WI
    yes! Incredible! ...have been following this and related threads....
    Mar 2004
    if anyone ever needs a very fast CAD\3D Designer....
    anyone with experience using friction belts got any sugestions for the design of the "tensioners"? i just have 2 nylon bushing holding the belt against the pulley now.. i think they may need to go closer together? should i put one on a spring-loaded cam?
    One thing I like is that if i update these photos, they update here also, so i can just change these to new ones when i do another few hours modeling. gonna put in all the bolt holes, and bolts and screws, "limit switch" whiskers, "optical" home sensor & tags. etc. i am also going to design a pneumatic manifold and a 3 color printhead.
    Any good ideas?
    Oct 2003
    Sturgeon Bay, WI
    ..just a thought...
    you could incorporate a toothed pulley on the motor and use a matching open-ended toothed belt to make a more positive drive.
    the nylon bushings could be on bearings to "roll" with the belt.
    Mar 2004
    the belt is a belt with a bunch of tiny teeth, and so is the pulley. its from an old dotmatrix printer.
    heres all my parts i have. all i need is to cut the acrylic, assemble the thing, and get 2 more xylotex drivers.
    the small stepper has gears and will push the lever on the airbrush via the bike brake cable.
    the tablet PC can run turboCNC, or other control software. the LCD will be used to configure the PIC microchip for the multicolor printhead when i do that.
    parts list, cost, and sources list forthcomming, as well as construction pictures.
    i have been waiting to have a project that i allready have all the parts for. finally! i am still collecting parts for a big "production" machine.
    Jun 2003
    Thumbs up
    Hey vacpress I was just wondering if you need a home? I have always wanted a son !! Now of course you would need to bring all your drawing tools with you cause I think I see some potential in you but it just needs to be developed....uh on my projects!
    Great drawings btw. I am curious as to what the use for this machine would be? Sign painting or ????
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Mar 2004
    the use of this machine is to massively waste the time of its creator!
    what else?
    its also the first step towards a www.pixation.com type product. i am thinking about using oil pant with little hoops running into it, and air jets blowing it off. the fun part is going to be programming the color-mixng algorithms.
    my drawing tools are nuthin-just pens, markers, and computers.
    its my machine tools you want.. check my user gallery.
  • Page 1 of 5 1234 ... LastLast
    1. Open Team Cheap DIY CNC Moving Gantry Router
      By pminmo in forum DIY CNC Router Table Machines
      Last Post: 08-19-2007, 02:59 PM
    2. CNC Gantry Painter Build Pics - Night 2
      By vacpress in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 11-02-2006, 07:52 AM
    3. Homebrew CNC Lathe
      By Deviant in forum General Metal Working Machines
      Last Post: 03-06-2005, 10:38 AM
    4. CNC Gantry Painter Build Pics - Night 1
      Last Post: 04-09-2004, 05:43 PM
    5. Imformation overload, Homebrew CNC
      By thuffner3 in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 02-28-2004, 12:20 AM
