Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 03-05-2007, 10:00 PM
Harryarmst is on a distinguished road
HP 7475a plotter questions
I have purchased a HP 7475a plotter to try and experiment with making vinyl decals. I have the plotter hooked up to a windows 98 machine and it seems to print fine. I have a couple of questions though:
1) When I create some text with a fancy font in powerpoint, it converts the fancy font to some other simple, single line font when it plots.
2) I am assuming there is a difference between printing from an application and plotting?
3) What type of application is compatible with this plotter that will plot (cut) the outline of a fancy type font?
4) Is there a simple app that someone can recommend that will just print text? I am just looking to make decals of text.
Thanks,
Harry in Orlando, FL
Old 03-09-2007, 12:44 PM
gregsnovas is on a distinguished road
try a free 2d cad program
http://www.freebyte.com/cad/cad.htm
in adobe illustrator or corel draw convert text to paths
that hp stores fonts to memory so if you use a cad drawing or a path form adobe illustrator it will plot fine
HP 7475A Plotter Help VNSPEC22 Printing, Scanners, Vinyl cutting and Plotters 26 08-22-2010 10:10 AM
Need help with 7475a plotter/vinyl cutter paper size hempuli Printing, Scanners, Vinyl cutting and Plotters 4 09-28-2009 02:29 PM
Looking for sharpie ink or plotter ink DrStein99 Printing, Scanners, Vinyl cutting and Plotters 22 11-26-2006 03:32 PM
Plotter conversion lez Open Source CNC Machine Designs 0 11-13-2006 02:55 PM
Plotter boards 2muchstuff Printing, Scanners, Vinyl cutting and Plotters 2 02-22-2006 12:50 PM
