Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 01-28-2007, 01:51 PM
velogirl is on a distinguished road
Mdx-3
I am not certain if this is the right place to post this in the forum but here goes. I am a newbie when it comes to a desktop 3d plotter
I have an roland mdx-3 which I acquired second-hand. It did not come with the software or manuals. Found the modela player and some information via some japanese pages but it seems that the machine isn't working appropriately or I just haven't set it up appropriately.
When it powers up the power button and view button are on. When I click the view button it goes down to what I assume is the mill start point of the table (bottom left), the led turns off, and then after 1 second it moves back into its original location (top right) and the led turns back on. At times when it goes back to origin, the power button starts to blink. I have tried connecting it via usb and parallel (lpt1) and have not been able to get it to function.
I have no idea how to troubleshoot this or set it up. If anyone has any experience with this machine or ideas on how to test it and/or set this up please let me know. Also any documentation leads would be great. I appreciate any and all help!!!
thanks!
maggie
Old 01-28-2007, 02:41 PM
Al_The_Man's Avatar
I would assume by their details on later models, that you would require a driver as it appears it just sets up a a printer, on either serial or parallel port.
Did you try contacting the US distributor for help.
Might be worth a shot.
Old 01-28-2007, 02:55 PM
thanks for your post.
as for contacting the distributer...yes i did. no answer from them and there is no documentation or support at this time for this specific model on their website or where to send for repairs. i am on to the japan distributer now as they have support until nov 2007 (online language translators are a godsend)
but no word yet on that end.
it might be that there is something wrong with the data transfer from the pc to the plotter itself...in that case it might need repairs but no clue where to take it for that.
thanks again,
maggie
Old 01-28-2007, 03:47 PM
Tony Mac is on a distinguished road
Hi Maggie,
If the machine is connected via the Parallel printer cable port, which I think it is? Download the attached toolpath file.
Open a DOS window
CD to the folder where your toolpath is saved
type,
copy profile.rol lpt1
You need to have a software package that save toolpaths for the Roland Modela machines (usually a .rol file extension). The Vectric software products can be used to run this machine and the Trial versions will let you save toolpaths using the Model postprocessor that you can then use to test whether the machine runs?
If you can make the machine run the we have a much simpler method of sending toolpaths to this machine.
I hope this helps and good luck,
Tony
File Type: zip profile.zip‎ (214 Bytes, 197 views)
Old 01-28-2007, 03:48 PM
Al_The_Man's Avatar
But if you don't have the driver..........
Old 01-28-2007, 03:54 PM
I've added a simple toolpath file that can be downloaded to test the procedure in my post.
Tony
Old 01-28-2007, 05:36 PM
thank you for your help tony
ok, when i type in the command prompt "copy profile.rol" it respondes with "1 file(s) copied. is that what I was supposed to get? let me know how to proceed with this.
thanks again,
maggie
Old 01-28-2007, 06:17 PM
Hi again,
You need the include the lpt1
If the machine is linked to the PC using the Parallel printer port cable the machine should start to move?
The file should simply run around a 1" square?
Or at least make a noise to indicate data has been sent to it?
Note - Not sure how yo udo this but the cutter head needs to be moved to the bottom left corner of the angled bed area as yo ulook at it. This machine takes the coordinates from wherever it is previously positioned.
Tony
Old 01-28-2007, 07:52 PM
strange...it doesn't move at all, not even a noise. the machine is connected to the parallel port with drivers installed. i guess i have another problem???
thanks,
maggie
Old 11-21-2007, 01:38 PM
Yvan256 is on a distinguished road
Talking
Originally Posted by Tony Mac View Post
Hi Maggie,
Open a DOS window
type,
Tony
I'm new here, but I just wanted to say that I've had a Modela MDX-3 for over 2 years now and thanks to your simple text file and MS-DOS command, my MDX-3 made its first moves since I've owned it.
I'm glad to see it works, and that it can take simple text files!
Now, if only I knew of a 3D CAD program for Mac OS X... I don't feel like working on the PC (ThinkPad 760XL, 800x600/65K, Pentium 166MMX, 64MB, 10GB)!
Roland Modela MDX-3
  #11   Ban this user!
Old 02-04-2008, 11:05 AM
nearboston is on a distinguished road
String Resurection
Hello,
I would like to resurrect this string, as I have just been given stewardship of an MDX-3/PIX-3 Tandem of machines. I have been able to find the driver and some of the software, but no Operating Manuals. The MDX-3 seems to operate, but I am having some problems. For example when I select the Tool Up and Down buttons on top of the MDX-3, the engraver motor spins, but the tool does not go up and down.
Any pointers to available documentation would be appreciated.
  #12   Ban this user!
Old 02-07-2008, 06:55 AM
feraldave is on a distinguished road
try Concepts 3d its built for mac
