Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 01-22-2007, 08:33 PM
hempuli is on a distinguished road
Need help with 7475a plotter/vinyl cutter paper size
I converted my 7475a pen plotter successfully into vinyl cutter. There are a few bumps here and there, but it mainly works good. My question to anyone who could know a solution to this:
1. Can I change the maximum paper size (A3/B or 11 inch x 17 inch) so that I can load paper/vinyl that is longer than 17 inches?
2. If yes, how do I go about it?
Thank you guys.
Old 01-23-2007, 08:52 PM
kennected is on a distinguished road
I don't know, but I know who does...
I don't know but these guys will.
http://www.winline.com/
I write own their plotter drivers for HPGL and they are excellent.
Very good tech support and they would know if you could use their drivers to extend the sheet size.
They are distributed by a company in Arizona and would likey answer your questions by phone.
Try this number-
928-427-9688
Good luck
Ken
Old 01-23-2007, 09:04 PM
Thank you much Ken! I will call them tonight or tomorrow.
Old 09-28-2009, 12:42 PM
bqproductions is on a distinguished road
What did you use for a blade holder
What did you use for a blade holder?
What kind of bumps did you have along the way. I am trying to do the same thing and I want to know ahead of time. Thanks!
Old 09-28-2009, 02:29 PM
CalG is on a distinguished road
Comprehensive documentation for HP instruments is available on line.
www.hpmuseum.net
Quite a listing, but the 7475 is in there. look for the pen plotter section There should be two documents at least.
CalG
HP 7475A Plotter Help VNSPEC22 Printing, Scanners, Vinyl cutting and Plotters 26 08-22-2010 10:10 AM
Newbie behind a Vinyl plotter...HELP iroc8210 Printing, Scanners, Vinyl cutting and Plotters 16 12-07-2008 10:18 PM
New vinyl cutter on way, need cheap mtl? carlnpa Printing, Scanners, Vinyl cutting and Plotters 4 10-16-2006 11:44 AM
Vinyl cutter/plotter jleiwig DIY-CNC Router Table Machines 7 11-29-2003 09:27 PM
HP Pen Plotter to Vinyl Cutter? tjstraz Printing, Scanners, Vinyl cutting and Plotters 6 08-05-2003 05:49 PM
