Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
  #25   Ban this user!
Old 12-18-2010, 01:32 AM
podocnemus is on a distinguished road
HP DraftPro Plus
Hi Doc
Going down the same route you di a short time ago
The plotter however is trying to pick up and deposit the cutter ( I am using a Mimaki holder and Knive which fit well and I need to fix the holder perminantly.
You mention you removed some of the carousel gears, Please would you be more specific
Help needed please
regards
Roger
  #26   Ban this user!
Old 01-10-2011, 08:12 AM
georgesusi is on a distinguished road
I too am in the process of converting a 7550A. I got it to run on Signgo last night. I'm running on XP with a serial to usb adaptor. It is made by ATEN. It lets you go out on the USB to a serial device. I had a problem at first because I did not identify the correct COM port. I looked in the control panel under ports and found where the ATEN adaptor was ported. I'm still fine tuning the output. I am interested in the pen holder that will work best. By the way I have a total of 9 (nine) pen plotters from the small desk top to the large roll type E size.
  #27   Ban this user!
Old 01-21-2011, 04:52 PM
bagherdn is on a distinguished road
may usefull
i think this will be usefull:
http://www.cnczone.com/forums/printi...l_cutting.html
