| Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here. |
| Replace the endmill with a paint nozzle or pen... ![]() 'Rekd
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
The complexity of this project depends on a lot of factors: Will the object to be printed be created by the same CNC so printing can just be another tool path? Will the print head/nozzle need to be perpendicular to the surface or can it remain in one direction for a printing pass (say, vertical to print the topographic terrain or maybe one direction at a time to print on an object from a few angles)? Do you want to print fine detail with a large color pallet or will an airbrush and a single color per pass be sufficient? If you want to paint the topology, like those 3D maps, I would use a simple airbrush in the tool holder. Break down a bit mapped image into individual colors and have the CNC scan over the surface while the bitmap is used to modulate the air flow. You could use the feed rate to synchronize scanning of the bit map but I would monitor the actual position. If your CNC has real time X,Y output then you can use that to coordinate the motion, otherwise I would tap into the encoder outputs to step through the bit map. Now if you want to do something more like an inkjet that can print on anything, that would be an extremely complicated, but amazingly interesting, project. |
I've developed a way to print on 3d surface once it has been cut out by cnc router through sublimation printing, but image distortion requires a lot of software correction prior to printing. Have a look at my website - www.3dsm.ltd.uk |
| G-Code to DXF | WayneHill | OpenSource Software | 189 | 01-30-2012 11:15 AM |
| Visual Basic Controller Project | dwwright | Visual Basic | 29 | 02-14-2011 02:24 PM |
| 3D wireframe surface | JW Peters | Autodesk Software (Autocad, Inventor etc) | 3 | 05-09-2005 08:23 PM |
| ME Consultant 2.0 - freeware | mrainey | Product Announcements & Manufacturer News | 12 | 10-10-2003 02:17 PM |
| Surface Hatching option ? | Ken_Shea | OneCNC | 2 | 06-13-2003 01:28 PM |
