Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 01-01-2004, 09:29 PM
Cold Fusion is on a distinguished road
Scanner to Cad?
I have a ton of flat metal pieces I want converted to Cad but don't have the time (or skills yet) to do them all. Could anyone point me to a good scanner to Cad program?
Proud owner of a Series II Bridgeport.
Old 01-02-2004, 01:05 AM
ger21's Avatar
Are you looking for Cad files to create g-code from? I don't think their really is a good one. Especially for less than several thousand $$$, and even those probably won't do what you're looking for.
Old 01-02-2004, 08:27 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
I'll hitch on ger21 here - if you're looking to get to G code then how about Scan2CNC? I think its a trial version - at least you might get some parts to G code but won't be able to CAD'em.
Jim
url if that helps:
http://www.gocadcam.info/software.html#scan2cnc
Old 01-02-2004, 09:04 AM
ToyMaker's Avatar
ToyMaker is on a distinguished road
But, if you are just looking to CAD your parts and/or drawings...
a really inexpensive route is an old (V8, V9, V10) Corel Draw off ebay. It has a raster-to-vector conversion that doesn't take too much cleanup (there are other, possibly better, R2V converters).
You can then export them as dxf.
robotic regards,
Tom
<edit: spell check>
Old 01-02-2004, 09:15 AM
Carver is on a distinguished road
How large are your parts? If they are under 60" or so it can be digitized very quickly. Otherwise simply drawing 2-d work is very quick.
If you can scan them on a regular desktop scanner, the program at the link below looks interesting.
http://www.graphconllc.com/
If you can get copy of Rhino and a microscribe digitizer, it is a slam dunk. The digitizer would be the real cost. Ed Kuhn at Remtek does about as good a deal on digitizers as I've found and is very quick to give a small shop a hand.
The URL is www.remtek.com
We are in Dallas and do this ( and 3-d) as a normal part of our business if you decide to send them out.
Best of luck,
Phill Pittman
digicarve@verizon.net
www.masterwerkes.com
Phill Pittman
phill@masterwerkes.com
Old 01-02-2004, 10:33 AM
The parts are aroud 4"x4".
Old 01-02-2004, 01:06 PM
I saw your parts on the other thread and would suggest the graphconllc conversion software, but this will still only get you the 2-d file.
The parts would be very easy to draw manually as well.
The g-code can be quickly generated by any of the near free programs described in the other thread.
Do you have any original paper drawings for reference and dimension? ( not for scanning )
Generating g-code is easy, but you will need to post process it for the controller for your machine.
All of this appears daunting but once you do it once, it gets simpler and is really worth the effort.
Take care,
Phill Pittman
Phill Pittman
Old 07-30-2005, 12:48 AM
dang's Avatar
dang is on a distinguished road
Will BobArt Pro X work for this application?
Old 07-30-2005, 11:31 AM
ger21's Avatar
I don't believe so, but I haven't used it so I may be wrong.
Free CAD software ynneb General CAM Discussion 5 07-08-2011 07:35 AM
=>Access Free CAD Projects CAD Ground Product Announcements & Manufacturer News 7 05-23-2005 02:03 AM
=> New CAD Projects Available CAD Ground Employment Opportunity 3 05-16-2005 03:45 PM
CAD Software , Which to choose!! Hasher General CAM Discussion 6 04-02-2005 09:22 AM
CAD Drafters Needed CAD Ground Employment Opportunity 0 03-11-2005 12:05 PM
