Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
  #13   Ban this user!
Old 09-23-2006, 10:50 PM
debogus's Avatar
debogus is on a distinguished road
That is really a simple design ,how big what font
I dont have anything loaded at the moment that will open it as vectors
Usually try saving as a dxf
I bought a grapphic disk ( calvin and asst BS) that had AI( eps) stuff mixed in
correl would open them then I would save as a format that vinyl exp could handle.
how about this kinda like it took 5 min on VE
  #14   Ban this user!
Old 03-22-2007, 08:56 PM
dixonjk is on a distinguished road
I had many issues importing from Illustrator when I first bought a Panther plotter. The tech support people tell me that even with the lastest updates you are soppose to use version 5.0 files!
  #15   Ban this user!
Old 10-27-2007, 01:45 PM
stoicjoker is on a distinguished road
Also, you can click on the cut/plot button and click the panel tab to see what "lines" or "paths" will be cut! Not that this helps you fix anything but at least you won't waste material! For VE LXI Apprentice software.
  #16   Ban this user!
Old 02-12-2008, 09:49 AM
SignFX is on a distinguished road
Hi Suzie,
Give this a whirl. I use to use the LXi software with one of my first plotters. Vinyl Express has you hooded when you buy there plotters as they only have one program capable of sending files to the plotter to be cut. That is the LXi Software. I use to cut AI files as well as EPS files simply by importing the image into Corel Draw. I would then copy the portion of the images I wanted to cut. Then I would copy and paste it into the LXi window. Sometimes when copy and pasting into LXI some object may become grouped strangly or distorted. To eliminate this convert the selected image to cureves in corel before copy and pasting.
The thing I discoverd was not to "IMPORT" to Lxi, but to copy and past instead.
I design everything in Corel Draw and copy and paste it into LXi when I use that plotter. I primarily cut on my Rolands and cut directly from Corel Draw.
It sounds like the graphic you are trying to cut is a simple design. It might be easier to redraw it in Corel. I know that is what I would do......I have found that I can usually recreate graphis sometimes faster and way less stress full that trying to import a impossible graphic.
Hope this helps you out.
  #17   Ban this user!
Old 12-07-2008, 09:18 PM
silbdesigns2 is on a distinguished road
Debogus
I am going to buy a vinyl cutter and I am new to this process.
The cutter I am looking at has the LXI software included.
Does the software work? I got the impresison that it is complicated to use. Woud appreciate any advice you can offer on the process
