Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
Thread: Free Tux Plot v2.2 for vinyl cutters, engravers, pen plotters etc
  1. #13
    Moderator ynneb's Avatar
    Feb 2004
    Oz
    Gary, I just carried out the two experiments and setting from your last two posts.
    I think I will try to find another printer cable. Yes you are correct that it does not have USB.
    I notice when the Gravograph boots up it says "Boot 2.1" followed by "Version2.5"
    I also went into the PC Bios to check the parallel settings. I scrolled through its options but it showed about 6 unrelated options, not ecp.
    I dont have a spare cable so it may take a day or tow b4 I post back.
    EDIT: Is there any way to avoid having to reload the job each time ?
  2. #14
    May 2008
    canada
    Quote Originally Posted by ynneb View Post
    Yes click the plot now button instead of "ok" it maintains the job for repeats. Or in advanced options toggle on the color to plot and select the "plot" button near the color bar. It will keep the job loaded also.
    In the bios it may be listed as epp also
  3. #15
    May 2008
    canada
    Tux Plot Version 3.0 is now available at the same website it has speed and feature improvements like nested fills and 4 simultaneous open job ability.
  4. #16
    Mar 2004
    Sweden
    Gary, I'm thinking of bying a used plotter. Is there any special model you think works better with Tux Plot?
    I need to cut long vinylstickers (sometimes over 3 m), but only 60 cm width (mostly at 15 cm though).
  • #17
    Gold Member
    Dec 2004
    Newtown, CT, USA
    Is there some reason this thread is in the LinuxCNC (formerly EMC2) forum?
    It certainly seems out of place since it doesn't seem to use LinuxCNC.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
  • #18
    Mar 2004
    Sweden
    Quote Originally Posted by lerman View Post
    Ken
    True, never thought about it. I moved it to a better location that hopefully gives more attention.
  • #19
    May 2008
    canada
    Quote Originally Posted by svenakela View Post
    If on an extreme budget (like $50) look for a roland pen plotter. They make fantastic vinyl cutters with the roland blade holder on ebay. I just found a 42" roland grx400ar plotter on kijiji with $200 in pens and manual for $40. They use standard HPGL code. If your budget is much higher a graphtec or roland are nice high quality machine, even the older models. (10 year old mercedes is still a nice car 10 years later )
    From my experience AVOID the imports from asia!!
  • Page 2 of 2 FirstFirst 12
    1. Need Help!- Inexpensive Laser Cutters/Engravers
      By hubery in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 07-14-2009, 10:52 AM
    2. New Chinese Vinyl Cutters
      By Halfnutz in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 12-30-2007, 08:35 AM
    3. Announcing a new UK supplier of Laser Engravers/Cutters
      By Strelitzia in forum Product and Manufacturer Announcements
      Last Post: 11-07-2006, 02:25 PM
    4. We Sell USA MADE Blades for vinyl Cutting plotters
      By worlde in forum Product and Manufacturer Announcements
      Last Post: 10-15-2004, 06:48 PM
