Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 03-23-2011, 10:39 AM
Mack the knife is on a distinguished road
Smile hot stepper.
Using a CNC plotter using I believe bi-polar, 8 motor connections down to 4 wires. When machine is sitting still the Y axis motor continues to heat up and up. Motor and drive have been exchanged and wiring checked, but an exchange motor in the Y axis position still heats without use,just holding. The original motor seems to have less detent than others now. Machine having to be run more slowly as it will fall over or loose position. Motor is Superior Electric MO61 CEO8. All 3 drives are the same, though, X axis has 2 motors, Z axis has a larger motor. Thanks for any help....
Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A guy2b1 DIY-CNC Router Table Machines 16 03-08-2011 05:50 AM
Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board wf1318 Stepper Motors and Drives 2 07-25-2010 02:19 AM
Integrated stepper motor? with built-in stepper motor driver uirobot Product Announcements & Manufacturer News 0 06-07-2010 03:59 AM
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 09:20 PM
difference between a stepper indexer and a stepper drive pcroxford Stepper Motors and Drives 0 11-02-2005 07:35 AM
