Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 01-25-2011, 07:29 PM
zonker is on a distinguished road
Need stencil cutting software advise
Hello all, I dont know if I have a real problem or if I have too many projects going on and am not sleeping enough so my brain malfunctions.
I have a homebuilt cnc router and have mounted a dragknife in it for cutting stencils. My problem is what software to use to cut the stencils. I have been using Vcarve and Artcam to produce g-code but Vcarve wants to vcarve as it designed to do and cuts both sides of the line. All I need is that the knife run one line where the line of separation would be. Is there any free software available for this? If not what other software would be recomended. I hope I have made my issue clear. Everything I am used to using does 2.5 d or 3d what I need is just 2d one cut run along the line of the design. Anyone?
I appreciate any input.
Visit Dagger and Rose 3D Vector Tattoos at http://daggrnrose.sqweebs.com
Old 03-13-2011, 11:40 PM
HamMan is on a distinguished road
Hello:
I am searching for the same information so if you end up with same please consider sharing.
Thanks,
HamMan
Old 03-14-2011, 01:12 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Check out this instructional video.
YouTube - Vector s For vinyl Cutting
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Need Help!- i need to buy a CNC laser cutting machine in malaysia, anyone can advise me? zaheer0047 Laser Engraving & Cutting Machines 16 03-27-2011 09:13 AM
DIY Stencil Cutting Drag Knife Solution - Update 4! airnocker Printing, Scanners, Vinyl cutting and Plotters 4 10-28-2010 12:39 PM
Software advise needed please. FriendOfGhost General CNC (Mill and Lathe) Control Software (NC) 5 03-22-2010 08:13 PM
Labels and stencil cutting laser, can you help, please? MR T999 Laser Engraving & Cutting Machines 0 11-04-2008 06:16 AM
Advise New cnc & software jchalter General CAM Discussion 2 06-20-2003 12:03 AM
