Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 01-17-2011, 08:35 PM
mfirdaus0708 is on a distinguished road
roland jwx-10 & mdx-40
Sincerely,
I have a machine JWX-10 & MDX-40, these machines have the same problem that when mounted rotary all the coordinates X, Y, Z & A such as collide and if calibrating the origin Y, Z axis always hit the rotary. If I move the X axis, Y & Z axis always participated, about what's the problem?
I've replace rotary board, mainboard & rotary motor, but the result is the same
thx
Old 01-26-2011, 07:01 AM
mahanta is on a distinguished road
I have jwx10 too and during 2 days when i want calibrate my machine the 1/8" pin dont countact with calibration rod and came back.After this When i push x-axis in jog mode the y-axis also move.And when i push y-axis,the x-axis also move.I dont know what happen?
Old 01-26-2011, 02:54 PM
awerby is on a distinguished road
Both these issues sound like
corrupted firmware. That's the software that controls the startup and zero-sensing routines. You should contact your local Roland dealers for instructions on how to download and reload the firmware for your machines.
Andrew Werby
ComputerSculpture.com — Home Page for Discount Hardware & Software
Old 01-26-2011, 10:00 PM
I also had to replace the mainboard TS-30 and the latest firmware update, and but same result ..
there may be colleagues who can help me for this problem, until now my machine can not be used if using a rotary, just use the table
Old 01-31-2011, 11:37 AM
My problem solved.I've bought new rotary axis from ProtoWizard in USA.I could calibrate my mill by this rotary axis.It must be isolated from machine table.If is not cause in jog mode X and Y collide.I isolated and solved my problem.
tkx
Roland MDX 540 fidia Benchtop Machines 6 04-05-2011 09:51 PM
Newbie- Roland mdx 40A? granth3 CNC Machining Centers 0 09-05-2010 01:58 PM
Looking for a Roland MDX-20 Polymerschmiede Want To Buy...Need help! 0 08-20-2010 10:16 PM
Roland mdx-40a vs ? streetsyndicate Commercial CNC Wood Routers 3 03-27-2010 05:15 PM
WTB: Roland MDX-20 star21 Want To Buy...Need help! 0 12-15-2009 11:24 PM
