Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 11-13-2010, 05:58 AM
woodenink is on a distinguished road
Help in Converting to 1 bit Bitmap
My lazer can only process 1 bit Bmp files, I use Photoshop to set up what I want, then convert to BitMap, that is where I strike problems!! The image or writing is ok until the Bitmap conversion, but after conversion to 1 bit Bitmap, my Script or image is no longer solid lines as I desire, usually has portions missing here and there, can be spotty etc. I have tried varied combinations in converting to Bitmap, such as Dither, halftone etc, some results are better than others, BUT what I really want is clear crisp letters or images without bits missing. Has anyone found a way around this problem, it has frustrated me for so long that I am at desperation point. Help me if you can I'm feeling down!!! Thanks, Amos
Old 11-13-2010, 11:20 AM
diecutter is on a distinguished road
I'm a rookie, but I'll throw this out for whatever it's worth. I have only had slight experience doing this, but when I did it turned out nice and sharp.
First I ran the art through the scanner as BLACK AND WHITE, 1 bit, and adjusted the contrast and darkness to the sharpest setting using the scanner's custom settings. Then in Photoshop I selected 1 bit depth and black and white and highest quality and saved the file. The result was sharp, dark lines which I converted to vector prior to cutting. It's worth a try.
Old 11-13-2010, 04:57 PM
Thanks for your advice, I will give it a go and report back here on the results. Amos
Old 11-16-2010, 05:00 PM
I tried finding those settings on my scanner and there were no such options on my scanner. sorry, Amos
Old 11-16-2010, 07:55 PM
george4657 is on a distinguished road
Take a look at a free program Paint.Net
It has a function Effects -> Artistic -> Ink Sketch
Set Coloring to 0 to have only black and white.
Adjust Ink Outline to desired effect.
Seems to work goods on pictures. You may want to supply a sample of what you are trying to convert.
Program is free just google paint.net
George
Old 11-17-2010, 08:41 AM
I have an HP scanjet 4400c, but other scanners are similair. What I do is make a preview scan, at which point it asks if you want advanced preferences. Click advanced and all the options are available.
It might be because I run my scanner through Photoshop that there are additional options, although I assumed they were always avaivable.
Greyscale bitmap to DXF or STL rweatherly Coding 6 08-20-2009 12:32 PM
Bitmap image to dxf Allsteel30 General CAD Discussion 0 06-10-2009 10:32 PM
Need Help!- Monochrome Bitmap weldr61 Torchmate 2 05-08-2009 11:51 AM
Need Help!- Bitmap to .EPS bengalsfan Printing, Scanners, Vinyl cutting and Plotters 5 05-12-2008 10:55 AM
Bitmap trace tdnp Vectric 8 02-20-2008 04:11 PM
