Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 09-09-2010, 09:26 AM
Fireflynj is on a distinguished road
cutting small vinyl sheets
I do not have a vinyl cutter at this time, but from what I saw on large format vinyl cutter they waste 3-4" on leading/trailing edge.
then what machine can cut sheets?
does anyone have experience cutting close to all four sides of vinyl sheets (8"x12")?
Old 09-21-2010, 02:01 PM
debogus's Avatar
debogus is on a distinguished road
Use the carrier sheets made for cricut.
Think they are 12 bucks for 2. Sold at Walmart
I use them for contiur cutting vinyl prints and heat tranfer prints.
Another use is paper for making stencils
With this you can use up the tinyest of scrap vinyl
Old 02-28-2012, 12:12 AM
CUTCNC's Avatar
CUTCNC is on a distinguished road
our vinly sticker cutter can cut 1mm vinly sheet, our min size is 900*600mm. Can add a laser lamp to improce location of printed pattern precision.
pattern cutting machine sales02@cutcnccam.com www.cutcnccam.com
CNC Vinyl cutting Darren_T DIY-CNC Router Table Machines 9 03-05-2011 06:01 AM
Need A Quote- Small quantity Acrylic/Clear Plastic Sheets with Simple Cuts Johnnybgood3 Employment Opportunity 6 09-04-2010 04:45 PM
Cutting 1" sheets of aluminum. Kalvin Benchtop Machines 10 05-06-2009 11:32 PM
Alternative hold down methods for small sheets Sonicmook56 Work Fixtures and Hold-Down Solutions 11 12-08-2008 11:04 AM
Cutting Aluminum Sheets barkster DIY-CNC Router Table Machines 26 03-01-2004 10:12 AM
