Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
Old 09-06-2010, 05:01 PM
airnocker is on a distinguished road
Thumbs up DIY Stencil Cutting Drag Knife Solution - Update 4!
Build your own inexpensive DIY swivel drag knife for your CNC mill.
To make your own DIY Swivel Drag Knife Cutter all you need are:
1. one .25" x .125" rare earth magnet from Amazon.com
2. one 5mm OD, 2mm ID bearing from http://www.bocabearings.com
3. one 4mm OD, 1.5mm ID bearing from http://www.bocabearings.com
4. one 3/8" x 12" brass tube from Hobby Town USA or your local hobby store
5. three Carl Goldberg 3/16" wheel collars from Hobby Town USA or local hobby store
6. one spring that slides easily down the 3/8" brass tube, has an ID > .25" and a compression force of 80-150 grams when compressed 3/16"
7. Roland replacement blades 45 or 60 degree from Ebay.com
8. A copper pipe cutter such as a Rigid Model 104.
9. A tiny amount of thin CA (Cyanoacrolate also known as Super Glue)
10. A tiny amount of Loctite 609
11. Digital calipers (very helpful)
To read the complete article go to:
http://www.buildyourtools.com/forums...rb_v=viewtopic
airnocker
Everything depends on everything else.
Old 09-06-2010, 09:13 PM
cad01 is on a distinguished road
or just buy one of the cricut blade holders. Could you really make it for much cheaper?
http://www.joann.com/joann/catalog/p...ODID=xprd74845
Old 09-08-2010, 11:09 AM
Buying a replacement blade holder may be the best solution for many people, but then one must make a threaded mounting adapter for the retail blade holder so it mounts on their particular CNC mill.
I made TWO swivel knife blade holders that mount easily in my CNC mill for under $15. So, yes, it can be done cheaper and be of better quality for those wanting vinyl/stencil cutting ability with their CNC mills.
I bought a Roland replacement blade holder for $20 and it doesn't pivot nearly as well.
Thanks for posting the Joann web link though. I'm always interested in learning new sources.
Old 09-20-2010, 09:50 PM
DIY Swivel Drag Knife - Update 5!
airnocker
There is a typing error in item #3 - the OD should read 5mm not 4mm.
Also item #5, Carl Goldberg wheel collars are not available any more but similar collars are available from Dubro or Great Planes brands. As you might have guessed I have these CG collars for a very long time.
This correction has been made in the buildyourtools.com forum as well.
I apologize for this oversight.
Old 10-28-2010, 12:39 PM
MikeSinclair is on a distinguished road
DIY Swivel/Drag knife - compensation
Does anyone know of a swivel knife compensation software package/processor/library? By compensation I mean what is described here
http://www.a2mc-cnc.com/downloads/do...g%20Knives.pdf
as well as a way to specify the blade's initial plunge angle for a free-swivelling blade.
Perhaps the most useful method of compensation would be to post-process a vector file (such as svg, wmf, dxf, etc) before sending it to the cutter. This would remove the cutter vendor dependency.
We were going to tackle this ourselves but thought if one existed...
Thanks for any help. -Mike
How to homebrew a drag knife for vinyl cutting abasir Printing, Scanners, Vinyl cutting and Plotters 11 11-01-2010 08:58 PM
Newbie- Replacing Spindle with Cutting Knife Hows it going to work? guy2b1 General Electronics Discussion 6 12-25-2009 09:21 AM
Newbie- Please help with CNC design for tangential knife cutting. jfmonod DIY-CNC Router Table Machines 11 02-25-2009 02:42 PM
Drag knife compensation algorithm ftkalcevic Coding 8 01-29-2009 03:37 PM
Labels and stencil cutting laser, can you help, please? MR T999 Laser Engraving & Cutting Machines 0 11-04-2008 06:16 AM
