Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Printing, Scanners, Vinyl cutting and Plotters
Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here.
  #13   Ban this user!
Old 03-26-2006, 02:50 PM
tauscnc's Avatar
tauscnc is on a distinguished road
Hey Carlo,
I assume the cutter are resharpen-able but I other then that no clue. I never checked to see if they make them in steel or other metals.
The stickers are not cut all the way through...just the vinyl. The backing is not cut other then maybe a small indentation. You will want just enough weight to get through the vinyl and nothing else. So the board under does not matter.
Orginally I had the spring design and it did cut into the board..the blade lasted about 5 min
taus
Thanks,
tauseef
www.cuttingedgecnc.com
  #14   Ban this user!
Old 03-27-2006, 07:36 AM
sbalder is on a distinguished road
There are services that regrind plotter blades; as myself I'll buy carbide blades in 5-packs off of Ebay and gauge the sharpness of a used blade by the sound it makes hitting the trash can. I've had good luck using cheap white laminate shelving board as a backing. It is stiff, smooth, cheap, and cleans up well.
  #15   Ban this user!
Old 03-27-2006, 09:40 AM
vacpress is on a distinguished road
For those who have built these things, how difficult might it be to make a regular roller-style vinyl cutter? Dot-matrix style.... I have seen projects like this. some look quite 'easy', others look horrible and difficult.. This seems like something idealy suited to DIY.. 2 motors! mechanical reduction, so you can use simple unipolar transistor drives? yes?
Robert
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
  #16   Ban this user!
Old 09-15-2006, 09:43 PM
Tracy is on a distinguished road
Hi, this is Tracy. we are manufacture in sign machine, we supply inkjet printer, solvent large format printer, vinyl cutter...
Meanwhile, in order to service the customers better, we still offer the related materials. please go to our website to learn something more.
www.foison.net.cn www.ad-materials.com
If you are interest, welcome to contact me: business@foison.net.cn
MSN:Tracy112831727@hotmail.com
  #17   Ban this user!
Old 06-22-2007, 04:59 PM
toofastdave is on a distinguished road
Originally Posted by tauscnc View Post
Hey Steven,
Good work also on the raptor stickers. From what I understand you have to setup the machine for the downforce. They must have some type of knurled screw that you turn to increase or decrease the force. You then have to cut a very small piece to see if it is set right. If all is well it will peel off with no problem. If you change the type of material (density, thickness, blade) then you have to readjust it. Maybe the really expensive ones are automatic.
taus
Wow, I have a K2 3925G machine and I am looking to buy a Vinyl cutter...but i think you have a great idea there... I may just go that route instead.. I have been laser cutting the Vinyl but the edges are amber in color...which is ok for darker stickers but for white vinyl it just doesn't look good.
-DD
  #18   Ban this user!
Old 03-26-2011, 04:32 PM
zea97 is on a distinguished road
Cool Cheap vinyl cutter
hey everyone!!! there is a set of 5 Roland 45 degree blades for $4.45 USD plus 3.99 USD shipping!!! here is the link New 5x 45° blade for Roland vinyl plotter cutter - eBay (item 190510128683 end time Apr-07-11 10:37:02 PDT)
CHeck out my website at zeacnc
Hey Sign makers (question on vinyl cutters) Darren_T DIY-CNC Router Table Machines 12 11-18-2008 12:43 PM
long cutter options Losos DIY-CNC Router Table Machines 28 06-28-2007 01:19 AM
Convert your router to cut vinyl and sand blast as well. ynneb Printing, Scanners, Vinyl cutting and Plotters 17 01-11-2007 09:09 PM
Looking into Plasma or Laser cutter for sheet metal NeoMoses CNC Plasma and Waterjet Machines 11 01-05-2005 11:29 PM
HP Pen Plotter to Vinyl Cutter? tjstraz Printing, Scanners, Vinyl cutting and Plotters 6 08-05-2003 04:49 PM
