| Printing, Scanners, Vinyl cutting and Plotters Discuss Printers, Scanners, Vinyl cutting machine and Plotting questions here. |
I have a HP 7585B plotter that runs the confidence test but won't talk to a pc. The best I can do is get an error light. I made a new cable according to the HP site that goes from 25 pin to 9 pin but it doesn't work. The guy I got it from was never able to get it to work either. I think that the serial port on the printer is bad. I have used several serial devices on the computer so I know the computer port works. I have tried using several different computers just to be sure but nothing happens. At this point I am considering just gutting the printers electronics. I can install new stepper drivers and drive it with Mach3. I would like to keep it running as a plotter as well since I would like to plot out some model airplane plans. I have several questions. 1. Any chance of getting it to run via the serial port? 2.What is a good sign cutting software package that will output either dxf, hpgl or Gcode? 3. Does anyone know of a way to convert Dr Stika files to dxf or something useable? I currently use Dr Stika on my Roland SX-8 and it works well. It however doesn't allow you to export anything. If I go the stepper conversion route I can always plot the airplane drawings since they are in dxf format and I can change pens manually. Thanks for any help that you can give. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| Hi Kipper, I have been using Dr Stika for my small cutter and I enjoy it. If I could get the plotter to work form the serial port then I could use that to do the cutting. Since I can't seem to get it to work I am looking for other options. Thanks for chipping in. Mike
| Any and all opinions are welcomed. I know I can gut it and run Mach3 on it but I would really like some input as to compatible software. Mike
| De Plotter de Plumas A3 a Plotter de corte y laser... | GTIHZ | Spanish CNCzone | 0 | 03-19-2010 11:37 PM |
| CNC PLOTTER | cjgaus | Printing, Scanners, Vinyl cutting and Plotters | 1 | 02-09-2010 02:27 AM |
| New Machine Build- Trials and Tribulations of a Noob | Turbo1zz | CNC Wood Router Project Log | 22 | 01-28-2010 04:28 PM |
| HP Plotter | djz9 | DIY-CNC Router Table Machines | 2 | 03-28-2008 12:22 AM |
| Plotter conversion | lez | Open Source CNC Machine Designs | 0 | 11-13-2006 01:55 PM |
