Results 1 to 2 of 2
Thread: HP 3500 CP wide format printer.. priting issue and Refilling help
    Aug 2005
    England
    Hello all.
    i ahve a HP Designjet 3500 CP wide format printer.
    after aot of screwing around i finally have it up and running.. at least test prints.. the problem is is that its only printing the first 5mm of any image down the right hand side,.. granted this is on windows 7. but i was hoping someone might have some insight.
    also if anyone has any tips on refilling this thing as the inks arn't in production anymore.
    Apr 2010
    dallas
    I feel that it is best that you go to authorized service center to get your printer fixed. They will use only original products for your printer and this will help it run longer. It might be a little expensive but I think it is well worth it.
    ____________________________________
    Wide Format Printer
  1. refilling ballscrew or linear bearing ?!?
    By veteq in forum Linear and Rotary Motion
    Last Post: 07-14-2011, 10:07 AM
  2. New Machine Build- extruded aluminum frames with rails from wide format plotters is there a market?
    By s1oejoe in forum DIY CNC Router Table Machines
    Last Post: 05-05-2008, 02:33 PM
  3. Build your own large format printer?
    By rackbox in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 06-16-2007, 11:07 AM
  4. Problem with plasma with a Whitney 3500 ATC
    By jmontes in forum General Waterjet
    Last Post: 06-26-2006, 12:20 AM
  5. Calcomp 3 foot wide inkjet printer
    By ynneb in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 07-01-2005, 08:22 AM
