- Com Port Problem
Com Port Problem
I have just added a Roland Picza 3-D Scanner to my computer. I have the Scanner working all right and I have the software installed, however I have a Com Port Problem. The message I get is: "Com 1 not ready, please verify that the port is valid or is not in use by another application"
I am assuming that the scanner hooked itself up to the same Com Port as my printer, and I am told that both cannot occupy the same port. If someone here could tell me how to configure this situation, I would be most grateful. I know it is done in Device Manager, but that is all I know.
Thank you,
Calabash
- Com Port Problem
- You may not post replies
- You may not edit your posts
Forum Rules
