It seems like the easiest way to do that would be to set the program to generate lines that are twice as close together, then delete every other one, starting on the outside. Either that, or find a real CAM program that can do what you want, while also doing all the other things CAM programs do, like ramping into the cut, stepping down in layers, setting speeds and feeds, calculating tool offsets, etc.
