Originally Posted by
Teknition
I did see one thing I would change BB. The gusset plates you have tacked on to the bottom tray, I would stitch weld them into the under side of the air bladder tank as stiffeners. Also tack some locating tabs around the perimeter of the inner and outer tray so you can bolt the 2 together and weld lifting lugs on the ends of the air bladder. This way if you need to clean the sludge out of the lower pan, you can unbolt and remove the air bladder for access. Other than that, its looking great to me.
What did you come up with for outer pan measurements?
Brad
