Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Thread: 4 x 5 Precision Plasma Build
  1. #13
    Aug 2009
    Quote Originally Posted by CNCmakers View Post
    Looks so simple.
    It is pretty easy with great quailty AMERICAN products, Now you got your plug listed twice. Putz...
  2. #14
    Aug 2009
    Quote Originally Posted by Handymancan View Post
    Ok so i skipped a few steps.. I have cut about 2' x 4' of widgets trying to dial this baby in. I cut about 25 of these widgets, actually they are the spacer i need between the clamp hasp on the torch and the handle base. So, now since i have never seen a plasma cut from somewhere else. is this good?
    Can I expect a better cut? Without the waves?
    Here are the settings I got the best cut for .075 mild steel
    Hypertherm Approx 39A , 104v
    Sheetcam 245 IPM
    Mach3 1000.2 Vel, 65 Accel
    Thc 18% 2/4 Volt
    Is this a z thing? I tried running with thc off but i think there is a default set somewhere that turns in on automatic.
    No dross or very very little.
    Slight Bevel, If I lower the volts below 96 I have to tap out the part from sheet.
    I read an old post that suggests removing ground from sensor card to stop electrical interference?
    I have the Dragon cut thc setup.
    Where is the smart-kut screen?
    No Ground, This widget cuts so quick i can't get my hand on it to check for vibration?
    OK so i figured something out. I flipped over the parts an noticed that the outline of the part was pretty clean, so maybe its the THC settings?
    I found out that I could turn the THC off right after I hit the run button.
    Here is my results... So the waves are from partially the machine setup & the THC settings. The waves did get smaller but yet they were longer? huh?
    Any suggestions would be greatly appreciated.
    Attached Thumbnails Attached Thumbnails 4 x 5 Precision Plasma Build-dsc06521.jpg
  3. #15
    Dec 2007
    Possible THC setting change
    Handymancan,
    I just received an e-mail today from a customer who had a cut quality issue that may be similar to yours on the same gantry. Here is what he did to improve the cuts.
    "Good Morning Ron, I received a tip from one other person on Tom's forum,
    to reduce the THC setting from 30% to 18% and that smoothed the cut
    lines out, so I'm still running your settings at a 100%."
    It may be worth a try to see if it improves your cuts.
  4. #16
    Jun 2010
    Quote Originally Posted by rchacich View Post
    Handymancan,
    Yep that was me sending the tip.. what I found on my PP gantry using mach 3 30% was way to high for THC %. Other people had me chasing my tail for ghosts. Once I talked to Ron about my loose gear and Matt about the % and set it to 15-18 Bam Problem solved. I use the upgraded Ball screw that You sell Ron. This tip was given to me by Matt @bulltear I still realy dont trust the THC to be unattended cutting but most of my cutting as of late is .25 -.375 material with no realy warp.
  1. Precision Plasma 4x4 CNC Table Build
    By unixadm in forum Precision Plasma
    Last Post: 06-02-2012, 03:23 PM
  2. New Precision Plasma Build 3x4
    By rock4xfab in forum Precision Plasma
    Last Post: 06-01-2011, 11:18 AM
  3. DIY CNC Precision Mill Design&Build
    By RogerRetro in forum General Metal Working Machines
    Last Post: 03-19-2008, 03:09 AM
  4. help a newbee, trying to build a cnc torch table
    By jim fuchs in forum Servo Motors and Drives
    Last Post: 01-18-2006, 02:45 AM
  5. Replies: 6
    Last Post: 03-05-2004, 11:11 PM
