Originally Posted by
Teknition
Hi WSS, sorry I was a bit late in replying, I somhow missed your post.
I used 10 ga for both the air bladder and the water tray. I'm sure you can get away with using lighter material as long as the appropriate cross bracing under the water tray and gusset plates inside the air bladder are used. When considering your sheet thickness and bracing, keep in mind that the water alone in the tank weighs alot (if my water tray was full to the top it would be pushing around 2500 lbs.) Then add to that the thickness of the material you are cutting and the total weight on the trays and table can add up pretty quickly. I see your table has 3 cross supports under your slats that will support the trays, you may want to consider adding some longitudinal support between the 3 cross braces to better support the bottom tray due to the added weight of the trays, water, and materials.
I went a bit on the thick side with the material selection for my table so If I decide later to add oxy/acet cutting to the table for thicker materials I wouldn't have to reinforce or redesign the trays.
I use Praxair's migmix Gold (90% argon, 10% co2) when welding all the table parts including the trays. I also utilized the pulsed mig capabilities of my Miller 350P to help limit heat input into the thin sheets. You can use a similar 2 gas composition or use the trimix. Trimix will assist in spray transfer, bead appearance and penetration, but will also make for a hotter arc. I think either of the gas mixes would be appropriate for the job at hand. For wire selection you are fine with 70s6 (aids in welding rusty/dirty steel) or 70s3 with .035, on the trays you could even use .024 if you wanted. I use .035 70s6. Whatever you decide to use, just take it slow and easy by stitch welding. It doesnt take much heat to make a warped up mess. I chose to weld my water tray inside and out for added insurance against leakage but as long as you are confident in your welds and overlap the stitching, the extra welding isn't really necessary. Just make sure to water test the outer tray when you are done welding it.
Brad
