Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: Precision Plasma LLC History
  1. #13
    Dec 2007
    3x4 Split Frame Table
    Another 2010 Precision Plasma LLC model is a 3 x 4 split frame plasma table. The actual travel is 40" x 50". Below are the benefits of this design.
    • Small footprint of 4' x 5'
    • Table consists of 2 fully welded frames
    • A water pan can be placed between the 2 frames
    • The 4' width allows it to fit in a pickup truck
    • The 2 frame design allows it to fit through a door, 1 piece at a time
    3 x 4 Table
  2. #14
    MBG
    MBG is offline
    Feb 2005
    uSA
    Just curious why is the design different on all the machines? Is it older models and you updated the design?
    I am talking about the gantry designs.
  3. #15
    Dec 2007
    The gantry designs have evolved over time. It has been to improve quality and reduce costs. If you study the machines from oldest to newest, you can see the progression over 3 years. The latest gantry, the 2x3, in a lower cost solution than our standard gantry and is only used on the small tables. This was designed to meet a specific price point for the small footprint tables.
    I anticipate that the current standard gantry design will remain the same for quite some time. We have (2) Z axis screw choices and the gantry works well direct drive or with 2:1 belt reduction units. It also has the optimal weight and rigidity for plasma cutting.
  1. Precision Plasma 4x4 CNC Table Build
    By unixadm in forum Precision Plasma
    Last Post: 06-02-2012, 03:23 PM
  2. New Precision Plasma Build 3x4
    By rock4xfab in forum Precision Plasma
    Last Post: 06-01-2011, 11:18 AM
  3. Precision Plasma LLC 3 x 4 table final assembly
    By rchacich in forum Precision Plasma
    Last Post: 09-06-2010, 11:23 AM
  4. Just IN- Precision Plasma LLC 6" rotary chuck for CNC plasma cutting
    By rchacich in forum Product and Manufacturer Announcements
    Last Post: 05-26-2010, 01:57 PM
  5. Just IN- Precision Plasma LLC 5' x 5' CNC Plasma Table
    Last Post: 11-10-2009, 11:08 AM
