Newbie Velox plasma Z axis suggestion for router
Results 1 to 3 of 3
Thread: Velox plasma Z axis suggestion for router
    May 2013
    Default Velox plasma Z axis suggestion for router
    I got the Plasma Z from velox. I saw a few vendors advertised their plasma to be compatible with router application.
    Has anyone with a Velox plasma Z found a good way to fix the floating plate to mount a router? Please share some thoughts and photos.
    Feb 2015
    Default Re: Velox plasma Z axis suggestion for router
    Don't Velox make a Z axis with a floating head already for plasma?
    - - - Updated - - -
    Seems so: http://www.ebay.co.uk/itm/VELOX-CNC-Plasma-Float-Head-4-5-Z-axis-Linear-Z-ZA450P-/112184331635?hash=item1a1eb50d73:g:NNIAAOxy1klRcZO J
    Jul 2005
    The floating plate overlaps the rigid plate that the lead screw is attached to and has a couple of keeper bolts in slots to let it slide up and down. I would either see if you can lock it down with those screws or perhaps drill and tap inot the rigid plate underneath and put in a locking screw Then you can attach a router mount to the "floationg plate" and do conventional routing
