Depends on what framework is left once you take off the water table. Commercial machines often have a phenolic grid but you can also do it in MDF (or layers of mdf) and then seal it with an epoxy sealer or similar (so it is air tight). You need it to be stable but you can get around the flat part (assuming it is close) when you mill the spoilboard down for use.
