Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 10-23-2009, 02:54 AM
qwerty1000 is on a distinguished road
feedrate wire
Hi guys!
It needs help!
How to modify the postprocessor.
Now, if you clearly indicate the feedrate, the post focuses on the slowest axis. Thus, reducing the rate of displacement in the center of the details. I need that constant velocity was maintained in the center of the details, so that the velocity on the axes grew up as needed. 'll Show please.
My postprocessor:
http://www.bukvorez.ru/musor/mpwfanuc.zip
Old 10-24-2009, 06:30 AM
Superman's Avatar
Superman is on a distinguished road
We also run a Fanuc wirecut (Robocut)
but we use the controls' pre-defined settings, the feedrates are not used in our programs
What machine do you have ?
Old 10-24-2009, 07:48 AM
foam cutter
foam cutter
http://www.bukvorez.ru/blog/_su-27.htm
Old 10-25-2009, 10:11 PM
weirdharold's Avatar
weirdharold is on a distinguished road
Smile Quick Hijack
Question for you Superman since you mentioned Fanuc Robocut. We have 3 Fanuc Series 180 iS-WB EDM's. Great machines. Can you drip feed these wire EDM's via a memory card ? The manual explain's how to download & upload to a card but nothing about using the card for memory & setting up & running the wire off of this. Hijack off.
Thank's,
Harold C.
(PS) We also use the controls' pre-defined settings, the feedrates are not used in our programs.
power supply size? for multi wire (total 250 inches of wire) DanOSB CNC Wire Foam Cutter Machines 5 03-02-2009 04:34 PM
EDM Wire feedrate DaveJ-FTM General Metalwork Discussion 3 02-02-2009 04:57 PM
Need Help!- G02, G03 Feedrate !!!!! usb TurboCNC 2 09-15-2008 07:19 PM
how to chandge the feedrate cob Mach Mill 5 06-23-2008 09:02 PM
Feedrate Override JFettig TurboCNC 2 12-09-2004 06:17 PM
