09-17-2009, 10:43 PM
Originally Posted by NIKEIME HI THERE!
I'M WORKING WITH MASTERCAM V8 WITH A FAGOR 8055M COMMAND. WITH THIS GENERAL POST I CAN'T PROGRAMMING DRILLS TO THIS COMMAND BECAUSE THE LETTERS DOESN'T MATCH WITH THE DEFINED CYCLES, FOR EXAMPLE I HAVE TO HAVE A CYCLE LIKE THIS: G69 G99 Z5 I B
Z= SECURE DISTANCE
I= DEPTH
B=peck,
BUT WHEN I USE THIS POST INSTEAD OF "I" APPEARS "Z".
I NEED YOUR HELP TO FIND ONE GOOD SOLUTION!!! THANKS! |
What I can tell you is that Mastercam has a good working post for the Fagor CNC here in the USA, I assume this is available for overseas too. Talk to your local Mastercam dealer.
Hope this kind of helps.
(As a side note, you can also program this cycle in a conversational-type automatic method at the CNC..... for example, simply key in the G81 command and press the "help" key and it'll prompt up a graphical picture and fill in the blank programming) |
