I set this up in my Control Definition, / Control topic's, / Arc. I know some post's have this switch, but you say your post does not have this feature. This is my set up with Mpmaster Control Def. in X3. hth.
Harold C.
I'm having problems, I want I & J values instead of R value.
I can't find the "arcoutput$" value in my postprocessor file.
I am adapting one Mcam V9.1 to McamX.
Anybody help!!!
thanks
Harold C.
Harol,
I did the changes that you suggested without good results.
Do you have something else in mind to help me out?
Regards
Did you try to look for "arctype" in your post? Type in type 2, not type 5 or 6
Beege,
I did change the arctype without good results.
please see attached doc file.
thanks
I don't know alot of anything about these post processers, but aren't I&J departure command's from where you start in a arc, and X&Y where your going to, forgive me if I"m out of line. Minard
