Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 01-16-2005, 11:15 PM
JWWalthall is on a distinguished road
Dyna 4400 pst help
I am trying to get a post for the Dyna 4400 mill to not output x and y values that are the same as the previous block. I have tried everything in the plin post line but I cannot get the state to change. The machine does not use standard G&M codes so it is not a normal post. The code that the mill uses is really awful but I need to get this post working so that I can reduce my file sizes. Anyone want a stab at this? Any help would be greatly appreciated as I need to cut parts as soon as I can. This post was one of the posts in the Mastercam V9 library.
Thanks,
Jim Walthall
Old 01-19-2005, 12:57 PM
masspfei is on a distinguished road
In the plin block, you should have something like the following
pxout, pyout, pzout, pfr, e
If is like this,
pfxout, pfyout, pfzout, pfr, e
then it is being forced out. change to first sample. If you need more help
email me your post.
masspfei@yahoo.com
Old 01-19-2005, 01:33 PM
Thanks, Masspfei for the responce. My troubles went away on Monday when the control bit the big one. I am now in the process of a retrofit then I will be able to get back to the real world of standard G& M codes. But again thanks for the advice I will check the post and try it just to see . It is allways good to learn on posts.
Cheers
Jim Walthall
Old 11-27-2006, 01:22 PM
Dan Mauch is on a distinguished road
Dyna 4400
I heard your controls bit the dust. If you retorfitted it how did you take care of the ATC? I may have a chance to pick up one of the. The guy has two both in good mechanical condition. I offered to retorfit one free for him giving me the other. He said yes
Dan Mauch
Camtronics Inc
www.camtronics-cnc.com
Dan Mauch
Camtronics Inc
dmauch@seanet.com
www.seanet.com/~dmauch
Old 12-15-2010, 06:38 AM
befega is on a distinguished road
Hi, I use Dyna myte4400H. I want to transfer the program from the pc. we bring the receiver state machine, such as the error text is on the E04. contribute to the solution I'll be glad you provide.
Thank you.
Hasan - Istanbul
Dyna Mechtronics cnc Knee Mill need help with control wisp Knee Vertical Mills 9 08-25-2011 04:35 AM
Dyna Mini CNC topazx2 Benchtop Machines 32 06-20-2010 01:44 PM
Dyna Myte 4400 (or other model) owners/users mmedina General Metal Working Machines 49 04-01-2010 11:22 AM
Ebay# 3855421933, FRAUD DYNA MYTE MILL davidponte CNCzone Club House 20 07-01-2005 09:09 AM
Dynamectronics 4400 Ernie General CAM Discussion 1 08-08-2003 04:05 AM
