| Is there a toggle in the post or in the configuration def's that will force mastercam to post the full code for each circular move. I am running mc9 with a heidenhain 430 control and the supplyed MPHEID.I post. The code looks like such.. N80G3X-.9889Y.5573I-.9264J.5573 N90G1Y-.8057 N100G3X-.9264Y-.8682J-.8057 in line 100 I need the "I-.9264" to be posted again. The control for some reason won't accept the repeated "I" from the previous line not being there. I have the post mostly the way I want it and this seems to be my only hitch. Any suggestions would be appreciated |
| ***COPY your post *** save the copy in another location, and restore if any problem arises Putting an "*" in front of a string forces Mcam to output the contained values to the NC-code, the IJK output also depends on the interpolating plane, G17 uses only I & J etc. find in your post parc #Select the arc output if arcoutput = zero | full_arc_flg | arc_pitch, [ #Arc output for IJK i, j, k replace with parc #Select the arc output if arcoutput = zero | full_arc_flg | arc_pitch, [ #Arc output for IJK # If you do NOT want to force out the I,J,K values, # remove the "*" asterisks on the *i, *j, *k 's below... if plane = zero, *i, *j, k #XY plane code - G17 if plane = one , i, *j, *k #YZ plane code - G19 if plane = two , *i, j, *k #XZ plane code - G18 the part in red was taken from the MPOKUMA.PST |
| Newbie- Circular Interpolation | Deadwood | Mach Software (ArtSoft software) | 3 | 01-11-2009 02:35 PM |
| circular interpolation | sqatch | Dolphin CADCAM | 9 | 02-11-2008 12:02 AM |
| Circular interpolation problem | L. Sakthivel | Fanuc | 3 | 10-17-2007 02:26 AM |
| No circular interpolation in G-Code? | M30 | Mastercam | 2 | 07-24-2007 09:55 PM |
| circular interpolation description | tom bryant | General Metal Working Machines | 6 | 05-26-2007 01:51 PM |
