| Adding a manual gear change call Yes i am trying to add a call for a manual gear change to my centriod post mc8. something like an if statment. If speed is < than 2500 post comment "M0 (CHANGE TO LOW GEAR)" IF speed is > than 2500 post comment " M0(CHANGE TO HIGH GEAR)" I am runnuing a BP series 2 with inverter and a manual switch to change from high to low which changes the spindle direction ,but would like a statement with a M0 to make the changes Thanks Brad
__________________ IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| If your conditional statements (if speed etc) work on the Centroid (or should it be 'if S' ?) and anything between the " " is a comment then I would say that the M0 has to be outside of the comment string to work. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Al thats what i dont know how to write it should work ,and I can put the M0 just before after it? this is the post ihave been messing with *progno, e "(PROGRAM NAME - ", progname, ")", e "(DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, ")", e psof0 # Start of file for tool zero psof psof # Start of file for non-zero tool number pinit !opcode n, "G17 G40 ; Setup for XY plane, no cutter comp," n, "G20 ; inch measurements" n, "G80 ; cancel canned cycles," n, "G90 ; absolute positioning," n, "M25 G49 ; Goto Z home, cancel tool length offset" n, pinc, *sg28ref, "X0.", "Y0.", e n, "M0" n, *t, "(CHANGE TOOL)" ptoolcomment pcomment n, "(CHECK GEAR)" would like to put the if statment here n, speed, *spdlon pcan pcan1, n, pasb, "G00", pwcs, *xr, *yr, strcantext pcan2 n, ptllncomp, *zr pcoolon any ideas?
| pcomment if speed <= 2500, n, "M0 (CHANGE TO LOW GEAR)", e if speed > 2500, n, " M0(CHANGE TO HIGH GEAR)", e n, speed, *spdlon I think if you add 2 lines it will work as you wish |
| I think what you want to do to compare the next spindle speed with the current spindle speed and if a high/low range is required, then output your M0 and comment. Otherwise you are going to get a "spindle speed high/low" at each speed change when you don't require a range-change. |
| Put this in ptlchg before the spindle output "Tested in version 9" if speed >= 2500, [ if prv_speed < 2500, "M00", "(CHANGE TO HIGH GEAR)", E ] if speed < 2500, [ if prv_speed > 2500, "M00", "(CHANGE TO LOW GEAR)", E ] |
| Manual Automatic Tool Change | ynneb | DIY-CNC Router Table Machines | 2 | 09-29-2004 01:21 PM |
| Basic Bevel Gear - Milling a valley for gear teeth | ngr1 | General CAM Discussion | 9 | 04-17-2004 04:58 PM |
| Metric Change Gear Combinations by J.W. Early Excel Spreadsheet | CNCadmin | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 05-26-2003 04:17 PM |
