| Post help Hello I've just been modifying a basic post-processor to suit the 1985 Denford Triac mill I have access to. I've now got everything tweaked to my satisfaction except for one thing. For feed rates in the X and Y, the triac requires FX to be defined, for moves in the Z, FX must be defined - e.g. G01 X150 Y50 FX100 Z150 FZ50 However, what the post produces is :- G01 X150 Y50 F100 Z150 F50 If I change the function defintion to FX then it replaces F wih FX all the time. Mastercam seems to know the difference between feed and plunge rates - but assigns the same variable to them both. Is there a way that I can get the post to insert FX and FZ as appropriate ? Any help would be great Thanks Dave |
| Davidimurray, I've had to configure a post myself. If you want to post/send the actual post file, I'd be more than willing to take a look and see if I can help. And if I can't help, there's several that will also be of assistance....guaranteed. ![]() *edited because I can't read* |
| David, what version of MC are you using?Send me the post please, and I fix for you. Regards Daniel |
| Hi everybody - thanks for the offers of help. I'm using MC 9. Please find enclosed the post file. It works just fine except that X and Y moves should be associated with a feed FX and Z moves should be associated with an FZ feed. At present all of them output FX and then manually go through and change the required ones to FZ. Thanks Again Dave |
| I was sitting here going through this, and got to thinking about something. How do you input 2 different feedrates in mastercam? I've never seen the option of having a feed for X and/or Y and a different feed for Z. |
| You can actually have 3. The first is for x & y. This is on the define tool page as feedrate. there are also plunge and retract feedrates available there Mark |
| Doh! Didn't even think of it that way. Now that you mention it, the plunge rate could be for X Y and Z (if ramping). But I don't know of any place to define 2 different feedrates for use on the same line. |
| It's up to the post to take the 2 types of feedrate and manipulate them so you get the desired result. Every post I've ever worked with just has one feedrate and whether it's used with z or x & y (or x, y & z as in the case of helical) determines if it's plunge or contouring. I've never seen one to output one such as asked for, but I'm sure it can be done. Might take a crack at it myself Mark |
| Hi David, I´m working in your post.I don´t read your reply before because a long holiday that we have here.But now all it´s Ok again.I already solve the problem.I´m testing now.Hang in there!!!! |
#10
| David, I put in attach with this reply your post. I create a rule in pst that when you have a move only in Z, put only FZ, when you have a move only in X or Y or both, put only FX, and when you have a 3 axis moves (XYZ) or X or Y move combined with Z (XZ OR YZ) the post put FX after X/Y values and FZ after Z value. Try and report to me your results. Like below: G90 G71 G54 X0 Y0 M06 T2 M00 ( CHANGE TOOL ) G98 M03 S2800 G00 X-15. Y5. Z2. G01 Z0. FZ215. <- Only FZ G01 X-20. FX230. <- Only FX G03 X-25. Y0. CX-20. Y0. G03 X0. Y-25. CX0. Y0. G03 X25. Y0. CX0. Y0. G03 X0. Y25. CX0. Y0. G03 X-25. Y0. CX0. Y0. G03 X-20. Y-5. CX-20. Y0. G01 X-15. G00 Z200. G00 X-102.186 Y62.554 G00 Z50. G00 Z2. G01 Z0. FZ220. G01 Y57.554 FX111. G03 X-97.186 Y52.554 CX-97.186 Y57.554 G01 X-89.686 G01 X91.685 FX110. Z31.98 FZ110. <- 3 axis move - FX and FZ respectively G01 X99.185 FX111. G03 X104.185 Y57.554 CX99.185 Y57.554 G01 Y62.554 G00 Z50. M06 T3 M00 ( CHANGE TOOL ) M03 S3000 G00 X-3.922 Y-66.05 Z-.107 G01 Z-2.107 FZ124. G01 Y-64.52 FX123. Z-.126 FZ123. G19 G02 X-3.922 Y-57.199 Z8.278 CX0. Y-2.138 G02 X-3.922 Y-49.89 Z13.5 CX0. Y-36.916 G02 X-3.922 Y-41.313 Z15.459 CX0. Y-41.313 G02 X-3.922 Y-39.686 Z15.392 CX0. Y-41.313 G02 X-3.922 Y-31.878 Z13.972 CX0. Y-42.853 G02 X-3.922 Y-23.884 Z11.555 CX0. Y-107.71 ..... Hope that helps.If work let me know. Kind Regards Note: Sorry my Bad English. Last edited by CAMFUN; 11-16-2004 at 10:58 AM. |
#11
| Hi camfun I've run the post a couple of times and all appears well. I haven't had time to test on the machine yet as I've been adjusting the gibs and sorting out a couple of other problems. As soon as I run a test (hopefully in the next few days) i'll let you know how I got on. Finally I'd just like to say a BIG BIG thanks to you for all your help. You've made me a very happy man. Thanks Again Dave |
#12
| Hi Camfun Ran a test program last night and everything worked perfectly. Thanks for the help - much appreciated Dave |
| Emco Compact 5 PC...have ???? | Double G | Mini Lathe | 42 | 08-22-2010 07:26 PM |
| Upgrading control hardware - Emco | eDudlik | General CNC (Mill and Lathe) Control Software (NC) | 21 | 12-08-2009 01:52 AM |
| v2xt post | jrrhotrod | Post Processors for MC | 25 | 12-10-2008 06:20 PM |
| post processor help | jrrhotrod | Post Processor Files | 8 | 01-14-2005 04:45 PM |
| One more little bump in the ProtoTrak post | Shadowfaxx | Post Processors for MC | 1 | 01-04-2005 11:10 PM |
