| Need post help for a Prototrak DPM-V3 I have been trying to edit the mpfan.pst file in MC9 to come up with something that works for a Prototrak DPM-V3 as the machine manufacturer suggests. It works but has several errors, the most annoying of which is that it calls up the tool that is already in the spindle and the prototrak runs up to the toolchange position after each call. This requires editing, a lot of repetitious editing. Has anyone had any success with this or has any other advice to offer? The mx2 and mx3 posts do not make 3D calls, so they are useless to me. Thanks for your help folks, |
| Open your post in your favorite text editor, and copy the functions: Code: ptlchg_com #Tool change common blocks () Code: ptlchg0 #Call from NCI null tool change (tool number repeats)
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Hi Matt, Sorry to be a pest, but I am lost here and apparently somewhat dense in this area. Where specifically in the file should I place this code? I have tried several places with unsatifactory results. "ptlchg0 #Call from NCI null tool change (tool number repeats)" was already in the code. I also have one other issue that has befuddled me. When a G2 or G3 is called and I, J or K have a value of 0 the post does not output a value for I,J or K. I need for that to happen otherwise the controller does a G1. Thanks |
| I meant for you to copy those functions from YOUR post and put them here for me to see it so I can try to find where your problem is. Sorry for the confusion. For the G02 G03 problem, I would guess your post is forcing the output of null values. Look for this Code: parc #Select the arc output
if arcoutput = zero,
#Arc output for IJK
if plane = zero, *i, *j, k
if plane = one, i, *j, *k
if plane = two, *i, j, *k
else,
#Arc output for R
if abs(sweep)<=180 | arcoutput=one, result = nwadrs(srad, arcrad)
else, result = nwadrs(srminus, arcrad)
*arcrad
] Code: if plane = zero, *i, *j, k Code: if plane = zero, i, j, k
| Thanks Matt, You put me in the right place to resolve the multiple tool call issue. It was just a matter of removing the asterisks from in front of several program calls and the arc error is now fixed too. Thanks again! |
| Cool shoes. If you have more problems with your post, let us know.
| I believe that I spoke too soon. I still have an error in that the post is calling "M06" at the end of each NCI operation regardless of the whether there is supposed to be a tool change or not. Removing the asterisk from in front of the "t" in the program line got rid of the multile T calls but not the multiple M06 calls. Also, is it possible to tell the post to output only linear moves, no arcs? The following is the affected code as it stands, I think. psof #Start of file for non-zero tool number pcuttype toolchng = one if ntools = one, [ #skip single tool outputs, stagetool must be on stagetool = m_one !next_tool ] "%", e *progno, e "(PROGRAM NAME - ", sprogname, ")", e "(DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, ")", e pbld, n, *smetric, e pbld, n, *sgcode, *sgplane, "G40", "G49", "G80", *sgabsinc, e sav_absinc = absinc if mi1 <= one, #Work coordinate system [ absinc = one pfbld, n, sgabsinc, *sg28ref, e pfbld, n, *sg28ref, e pfbld, n, "G92", *xh, *yh, *zh, e absinc = sav_absinc ] pcom_moveb c_mmlt #Multiple tool subprogram call ptoolcomment comment pcan if stagetool >= zero, pbld, n, t, "M6", e pindex if mi1 > one, absinc = zero pcan1, pbld, n, sgcode, sgabsinc, pwcs, pfxout, pfyout, pfcout, *speed, *spindle, pgear, strcantext, e pbld, n, "G43", tlngno, pfzout, scoolant, next_tool, e absinc = sav_absinc pcom_movea toolchng = zero c_msng #Single tool subprogram call ptlchg0 #Call from NCI null tool change (tool number repeats) pcuttype pcom_moveb c_mmlt #Multiple tool subprogram call comment pcan pbld, n, sgplane, e pspindchng pbld, n, scoolant, e if mi1 > one & workofs <> prv_workofs, [ sav_absinc = absinc absinc = zero pbld, n, sgabsinc, pwcs, pfxout, pfyout, pfzout, pfcout, e pe_inc_calc ps_inc_calc absinc = sav_absinc ] if cuttype = zero, ppos_cax_lin if gcode = one, plinout else, prapidout pcom_movea c_msng #Single tool subprogram call ptlchg #Tool change pcuttype toolchng = one if mi1 = one, #Work coordinate system [ pfbld, n, sg28ref, e pfbld, n, "G92", *xh, *yh, *zh, e ] pbld, n, "M01", e pcom_moveb c_mmlt #Multiple tool subprogram call ptoolcomment comment pcan pbld, n, t, sm06 pindex sav_absinc = absinc if mi1 > one, absinc = zero pcan1, pbld, n, sgcode, sgabsinc, pwcs, pfxout, pfyout, pfcout, speed, spindle, pgear, strcantext, e pbld, n, "G43", tlngno, pfzout, scoolant, next_tool, e absinc = sav_absinc pcom_movea toolchng = zero c_msng #Single tool subprogram call pretract #End of tool path, toolchange sav_absinc = absinc absinc = one sav_coolant = coolant coolant = zero #cc_pos is reset in the toolchange here cc_pos = zero gcode = zero pcan pbld, n, sccomp, sm05, psub_end_mny, e pcan1, pbld, n, sgabsinc, sgcode, sg28ref, scoolant, strcantext, e pbld, n, sg28ref, protretinc, e pcan2 absinc = sav_absinc coolant = sav_coolant Last edited by Shadowfaxx; 11-01-2004 at 04:25 PM. |
| This is a null message. I oopsed |
| Emco Compact 5 PC...have ???? | Double G | Mini Lathe | 42 | 08-22-2010 07:26 PM |
| Upgrading control hardware - Emco | eDudlik | General CNC (Mill and Lathe) Control Software (NC) | 21 | 12-08-2009 01:52 AM |
| v2xt post | jrrhotrod | Post Processors for MC | 25 | 12-10-2008 06:20 PM |
| One more little bump in the ProtoTrak post | Shadowfaxx | Post Processors for MC | 1 | 01-04-2005 11:10 PM |
| Continued post help for Prototrak DPM | Shadowfaxx | Mastercam | 3 | 11-04-2004 03:16 PM |
