| hello every one!!!! i'm having a big problem trying to make(modify) a postprocessor to a adapted convencional lathe machine. to a CNC whith 2 tool to drill at the same time in the same piece. the holes to do is simetrical, so the piece rotate in C axis, and the drills are posicioned in X and Y axis, and move cuttind in Z axis. Mastercam version: X2 The controler is fanuc-OT example from code accepted: % O2770 N0001 G90 (PROG ABS) N0002 M54 (ASPIR ON) N0003 M32 (REFRIGERATION X ON) N0004 M33 (REFRIGERATION Y ON) +----------------------------------------------- N0005 G55 N0006 T03 (2 SHORT DRILL D 8) N0007 G00 G43 H03 Z20.000 S2000 M08 N0008 G00 G90 C0.000 N0009 G00 X69.000 Y69.000 N0010 M24 (MOTOR X ON) N0011 M25 (MOTOR Y ON) N0012 G00 G90 C10.000 N0013 M98 P171001 N0016 M28 (MOTOR X OFF) N0017 M29 (MOTOR Y OFF) N0018 G00 G90 Z250.000 N0019 G00 G90 C0.000 M09 N0020 M00 (stop) N0026 M30 +-------------------------------------- O1001 N0226 G90 N0227 G00 Z5.000 N0228 G01 Z-4.000 F100 N0229 G01 Z-25.000 F200 N0230 G00 Z5.000 N0231 G91 C10.000 N0232 M99 % drawing of axis: ![]() my problem: - output from mastercam to gcode the line : N0009 G00 X69.000 Y69.000 - outut the correct angle in C axis: N0008 G00 G90 C0.000 anyone have any idea? i already have contacted my mastercam resseler, but he don't give me no positive feedback. So, i don't want to give up so easly.... tanks in advance for any sugestion, and sorry for my poor english... |
| OK, Since nobody has offered to help you... I really do not see anything wrong with your code except your drawing shows 140mm bolt circle and your code gives 138mm diameter. Please post an example of the code you are getting from MasterCam and a copy of the post file you are trying to modify and I will take a look at it. If you can, please post a copy of your MasterCam file in V9 format. I can not promise a quick fix but, I will try.
__________________ ObrienDave. MasterCam since V6. Gcode since 1983. Be careful, the nose you punch today may belong to the butt you have to kiss tomorrow. Last edited by ObrienDave; 11-30-2009 at 11:18 AM. |
| Tags |
| lathe, mastercam, postprocessor |
| mastercam x2 postprocessor | bizdad | Mastercam | 3 | 10-12-2008 05:05 AM |
| Newbie- Mastercam X2 postprocessor Heidenhain TNC355 | Glitter | Post Processor Files | 0 | 09-29-2008 10:09 AM |
| Need Help!- mastercam x2 mr2 Postprocessor need for motionmaster 5axis router 8055 fagor | oscarrivera20 | Post Processor Files | 0 | 06-04-2008 09:39 AM |
| mastercam postprocessor 5 axis | pgman68 | Post Processor Files | 0 | 05-06-2008 08:26 PM |
| Mastercam 9 Postprocessor for Matsuura MC500V mini-master | luis_gts | Post Processor Files | 5 | 06-04-2007 02:04 PM |
