Hi Guys I have been running my VMC for almost 3 years with a Fagor 8055 controller. I am using MCX and have just fitted a 4th axis on the machine, and I am unable to get my post to work correctly. The 4th axis works clockwise for all positive(+) degrees and CCW for all negative degrees(-). Below I have attached part of the code that was generated, when it tells the 4th axis to go 15 to 14 the unit will turn clockwise which is 359 degrees to reach 14 degress instead of taking the shortest route which should have been -14 degrees. I have tried changing some things in the machine definitions but I have had no luck. I have also attached parts of the post processor that I think need to be modified. I don't know much about editing a post, any help will be greatly appreciated Cheers Jaangi Tis is part of the code that the post generated. ;T97 : 3. BALL ENDMILL : D3.0000mm : M.FINISH... N100 G00 G17 G40 G71 G80 G90 N110 T97 ; 3. BALL ENDMILL N120 M06 N130 ;TOOLPATH - FINISH4 N140 ;STOCK LEFT ON DRIVE SURFS = 0. N150 G54 N160 G00 G90 X-138.076 Y0. A8.449 S3500 M03 N170 G43 D97 Z132.274 N180 Z34.274 N190 G01 Z32.274 F101.8 N200 Z32.27 A8.896 F361.6 N210 Z32.287 A10.034 N220 Z32.272 A12.797 N230 Z32.279 A13.189 N240 G00 Z37.279 N250 X-138.571 Z37.283 A15.755 N260 Z34.283 N270 G01 Z32.283 F101.8 N280 Z32.275 A15.438 F361.2 N290 Z32.291 A14.019 N300 Z32.278 A10.534 N310 Z32.283 A10.363 N320 Z32.287 A10.008 ---------- # General Output Settings # -------------------------------------------------------------------------- spaces$ : 1 #Number of spaces to add between fields omitseq$ : no$ #Omit sequence numbers? seqmax$ : 9999 #Max. sequence number arcoutput$ : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180 arctype$ : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc. breakarcs$ : 2 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs do_full_arc$ : 0 #Allow full circle output? 0=no, 1=yes helix_arc$ : 1 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only maxrad$ : 999 #Maximum arc radius hel_2100 : no$ #Acramatic 2100 style helical moves, 0=no, 1=yes usecanned : yes$ #Use canned drilling cycles? Set to no for long output. wcstype : 3 #0 = G92 at start, 1 = G92 at toolchanges, 2 = G54, 3 = Off force_wcs : 0 #Force WCS output at every toolchange? stagetool : 0 #0 = Do not pre-stage tools, 1 = Stage tools tool_table : 1 #Tool table, 0=no, 1=yes, 2=Predator VCNC, 3=MetaCut View output_z : yes$ #Output Z Min and Z Max values (yes or no) cool_zmove : yes$ #Coolant off with last move use_pitch : 0 #0 = Use feed for tapping, 1 = Use pitch for tapping maxfeedpm : 500 #Limit for feed in inch/min maxfeedpm_m : 10000 #Limit for feed in mm/min use_gear : 0 #Output gear selection code, 0=no, 1=yes max_speed : 10000 #Maximum spindle speed min_speed : 50 #Minimum spindle speed sextnc$ .PIM #NC extension override ----------- # Rotary Axis Settings # -------------------------------------------------------------------------- # Typical Vertical srotary "A" #Rotary axis prefix vmc : 1 #0 = Horizontal Machine, 1 = Vertical Mill rot_on_x : 1 #Default Rotary Axis Orientation, See ques. 164. #0 = Off, 1 = About X, 2 = About Y, 3 = About Z # Typical Horizontal #srotary "B" #Rotary axis prefix #vmc : 0 #0 = Horizontal Machine, 1 = Vertical Mill #rot_on_x : 2 #Default Rotary Axis Orientation, See ques. 164. # #0 = Off, 1 = About X, 2 = About Y, 3 = About Z rot_ccw_pos : 1 #Axis signed dir, 0 = CW positive, 1 = CCW positive ret_on_indx : 1 #Machine home retract on rotary index moves, (0 = no, 1 = yes) index : 0 #Use index positioning, 0 = Full Rotary, 1 = Index only ctable : 1 #Degrees for each index step with indexing spindle one_rev : 1 #Limit rotary indexing between 0 and 360? (0 = No, 1 = Yes) lock_codes : 0 #Use rotary axis unlock/lock M-Codes? (0 = No, 1 = Yes) use_frinv : 0 #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes) rot_feed : 1 #Use calculated rotary feed values, (0 = no, 1 = yes) maxfrdeg : 2000 #Limit for feed in deg/min maxfrinv : 999.99#Limit for feed inverse time frc_cinit : 1 #Force C axis reset at toolchange ctol : 225 #Tolerance in deg. before rev flag changes ixtol : 0.01 #Tolerance in deg. for index error frdegstp : 10 #Step limit for rotary feed in deg/min #Rotary/Index variables csav : 0 #C saved value prvcabs : 0 #Saved cabs from pe_inc_calc, #Used for rotary feed and direction calculations cdelta : 0 #Calculation for angle change rev : 0 #Calculation for deg/min sav_rev : 0 #Saved revolution counter indx_out : c9k #Rotation direction calculation fmt 16 indx_mc #Rotation direction calculation #Vector Constants for Rotatary Calculations aaxisx : 1 #A axis rotation vector constant aaxisy : 0 #A axis rotation vector constant aaxisz : 0 #A axis rotation vector constant baxisx : 0 #B axis rotation vector constant baxisy : 1 #B axis rotation vector constant baxisz : 0 #B axis rotation vector constant caxisx : 0 #C axis rotation vector constant caxisy : 0 #C axis rotation vector constant caxisz : 1 #C axis rotation vector constant #Feedrate calculation variables frdelta : 0 #Calculation for deg/min frinv : 0 #Feedrate inverse time frdeg : 0 #Feedrate deg/min actual prvfrdeg : 0 #Feedrate deg/min actual ldelta : 0 #Calculation for deg/min, linear cldelta : 0 #Calculation for deg/min, linear and rotary circum : 0 #Calculation for deg/min ipr_type : 0 #Feedrate for Rotary, 0 = UPM, 1 = DPM, 2 = Inverse |
| Need Help!- Fagor 4 axis post help | jaangi | Post Processor Files | 0 | 08-23-2008 11:23 PM |
| Just IN- New Guy from Dunedin looking for Fagor post | Dazz88 | Australia, New Zealand Club house | 7 | 06-30-2008 07:23 PM |
| Following Error...Fagor 800t on lathe (X,Z axis) | jime | General Metal Working Machines | 4 | 03-23-2008 04:50 AM |
| Fagor 8025 TG Accuslide Z axis trouble | Tat2nu | General Metalwork Discussion | 1 | 07-05-2007 08:06 PM |
| Fagor 8055i Post | jaangi | Post Processors for MC | 1 | 03-30-2006 01:19 PM |
