Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 06-12-2008, 09:42 PM
SAVORYVILLEMACH is on a distinguished road
have posting conflicts with prototrak MX3
I use version 9 master cam with the MPROTMX3.pst When I load the program in to the prototrack, the program doesn't have a spindle speed command which is needed for this machine, and It doesn't load the rapid clearance planes for the drill cycles. it starts the drilling from the clearance plane. I loaded it into this machine as a .CAM file. All help is appreciated.
Old 06-16-2008, 11:11 PM
Mike Mattera's Avatar
Gold Member
Mike Mattera is on a distinguished road
Does the Prototrak support drilling with a high retract (Clearance plane) move?
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
Old 06-21-2008, 07:55 AM
I believe it does,
Old 07-09-2008, 07:54 PM
Alex_Cole's Avatar
Alex_Cole is on a distinguished road
These are very easy modifications for your Mastercam reseller to correct. I would recommend contacting them and send them your files.
MC9 with toolpaths
NC program with notes explaining what needs changed
your post processor files
You are going to need to know what corrections are needed to the code for the machine to run. I believe this is what Mike was getting at. You need to look in your manual and see if a value is missing from the drilling output that is causing the drill to start from the clearance plane, or is there a position output missing prior to the drilling op that your machine uses for a return point.
If your local dealer has to do the research they will have a harder time helping. This same thing applies on here. We would need to know the details to be ale to help more.
HTH
AC
AC
Has anyone seen my pillow?
Need Help!- Prototrak SM bikerdude710 General CNC (Mill and Lathe) Control Software (NC) 3 11-10-2010 08:10 PM
prototrak vs. bridgeport JIMMY Bridgeport and Hardinge Mills 4 10-26-2006 09:19 PM
ProtoTRAK posts bpmufx Mastercam 11 04-07-2006 11:51 AM
Help Drilling on Prototrak SM sdante General CNC (Mill and Lathe) Control Software (NC) 1 11-18-2005 04:43 PM
Prototrak CNC 2 information jimglass General CNC (Mill and Lathe) Control Software (NC) 0 11-14-2005 05:34 PM
